Okay have been reading through all of these posts about alternators and such and cant find the crucial info that I need about my alternator. I have a 71 F250 with a 390 and was thinking about going to a 1 wire alternator. First what alternator do I use and what about the brackets? and second where do you hook it up?? I really dont see how it could be a one wire when you need a output wire and also a input wire to turn the alternator on right? But at least I could get rid of some wiring and also the external regulator. So if you have some down and dirty information about this it would be appreciated.
I don't see the big advantage of having one wire alternators. Having changed external and internal regulators, I find that external regulators have the advantage. I don't have to disassemble the alternator. It's so much easier.
Originally posted by Faithful Old Road Dog I don't see the big advantage of having one wire alternators. Having changed external and internal regulators, I find that external regulators have the advantage. I don't have to disassemble the alternator. It's so much easier.
Not to mention that many people will simply replace the alternator because the internal regulator goes bad. Much cheaper in the long run to go with a stock setup.
So your telling me that the one wire alternator is from a chevy? The reason that I would like to go to the one wire is that the owners before was a hack and cut and spliced everything everywhere. I spent a long time rewiring the alternator and volt reg trying to get the system to charge correctly. So was thinking that maybe could reduce some clutter and make it more simple. You know the saying K.I.S.S.. Any help of what alternator to buy would be appreciated. Thanks
Originally posted by Ron Kelley So your telling me that the one wire alternator is from a chevy? The reason that I would like to go to the one wire is that the owners before was a hack and cut and spliced everything everywhere. I spent a long time rewiring the alternator and volt reg trying to get the system to charge correctly. So was thinking that maybe could reduce some clutter and make it more simple. You know the saying K.I.S.S.. Any help of what alternator to buy would be appreciated. Thanks
RJK
The 1-wire alternator was originally made for chevy's (GM in general) and as such, it's like the rest of General Maintanence, er, Motors stuff. It's everywhere, and everyone has one, it seems.
Just my opinion, though, like I said. If it works for you, then more power to you, especially considering a wire-harness nightmare like you speak of
Yep, the 1-wire deal uses a GM alternator. They are very popular when converting old tractors from 6V to 12V but I refused to go that route with my 1964 Ford 2000. I used a Ford alternator with external regulator and wired it myself using the diagram in my 69 Ranger's service manual. It's been working fine for over 2 years now.
This one is for use with an idiot light, like my tractor has:
I really like the alternators found on mid 80's- mid 90's ford trucks .There is only two wires to hook up. It looks like more at the alt, but if you follow the harness to the starter relay you'll find that there is 1 wire that connects to the hot side of the relay and a small engizer wire (hot with key on).These are the alternator's that have a gray box on the back. that is the regulator and the brushes ,so you don't have to open the alt to change either one!
Johnny
Hey thanks everybody. I am in total agreement about keeping a ford a ford. Especially thanks for the diagram. THat is the best diagram that I have seen yet for this system. Finally a picture that accurately tell you where the ammeter is supposed to be hooked up to. Somewhere along the line somebody had it hooked up to the +bat and the other side to ground. I found this when i took off the instrument cluster and seen all the melted panel on the back of it. So I disconnected the wires out in the engine and fixed the panel on the back of the cluster but then was wondering where they are supposed to be hooked up to so the diagram really helps. Thanks a lot everybody. I also will maybe look into the 80 and 90's ford alternators.
O.K. guys. I finally got to the point in my restoration where I could come with something on a nice alt. set up. This alt. is from a 1994 Ford aerostar.It actualy had a Napa tag on it with a part # of 213-3086.It is rated at 95 amps . The wiring is from a 1994 F150 .I chose this wiring becuase the alt ,relay, and Battery are in the same postion as our trucks. This thing only uses Two wires. One hooks to the hot side of the relay .The other hooks to our factory enigizer wire.It mounts in the factory location using the factory(our truck) spacer and V pully.The pulley installs with No spacer or fan .The donor alt. uses internal fan.The only modifiction is to remove about 1/8- 1/16 from the back side of the pulley edge.Ther is pics of the wiring in My gallery. This is only my 390.The back of the alt is close to the block ,but doesn't hit.
i had the same thing with mine. I could never get it to charge right no matter what rpm it was at. Some fool had tried the one wire concept and cut and hacked all kinda wires off the harness. it took me three weeks walking thru part yards and climbing thru trucks to find an orignal harness with all the wires intact. I bought a new alternator and a new regulater and now i have rewired my truck and have no problems with charging at all.
