alternator issues
Old Mar 15, 2011 | 01:13 PM
frenchy107's Avatar
frenchy107
alternator issues
my alternator on my 89 f150 with a 300 keeps melting the wires that lead over to the starter solinoid on the fender, im using a 12 gauge wire at the moment, should o go to a thicker wire? or find an old harness from a boneyard?
Old Mar 15, 2011 | 01:35 PM
rla2005's Avatar
rla2005
Your previous post ( https://www.ford-trucks.com/forums/1...or-issues.html )led me to believe you were not getting any alternator output?
That 12 gauge wire is only good for roughly 20 amps. Yes I know the factory has seriously under sized the wire but it will not hold up to a long term current draw. Your alternator is most likely a 60 or 75 amp model. If something is drawing a large amount of current that wimpy charge wire is going to melt.
I suggest you find out what is drawing so much current. Have you installed accessories such as extra lights, winch, amplifier, etc.? Once you have the current draw issue resolved you might consider a 3G alternator and larger charge wire upgrade. The 2G alternator connector is a documented fire hazard.
Old Mar 15, 2011 | 02:07 PM
frenchy107's Avatar
frenchy107
no additional accessories have been installed, i keep the upgrade in mind, gonna try to rig something for now
Oscar Walker
17
Apr 3, 2013 11:09 AM
zehcnasca
Nov 20, 2011 08:37 PM
lasthighboy
Electrical Systems/Wiring
Nov 30, 2008 05:07 PM
medicpg
31
May 20, 2003 09:55 AM
