fuel system too lean
Old Nov 4, 2002 | 03:47 PM
Xizang11's Avatar
Xizang11
my check engine light came on while i was away (Army stuff)
when i got back (oct. 11) i pulled the codes.
"fuel too lean bank 1, bank 2"
i'm thinking vaccum leak, but have heard the o2 sensors could be playing a part here too. penny for your thoughts.
Old Nov 4, 2002 | 04:04 PM
JohnBon's Avatar
JohnBon
I'm facing the same problem. I've read that it is usually not the O2 sensors..that it is usually vaccum(if at idler light throttle)..or insufficient fueling (if at heavy load)..but I've also seen mentions of MAF...good, coolant temp sensor..
Questioon..does your vehicle run hot??
John
Old Nov 7, 2002 | 09:52 PM
kevincook's Avatar
kevincook
When you have the same concern on both banks you have to look at stuff that effects both banks. Before looking for vac. leaks I would recomend checking fuel pressure if you have a gauge. If it has lots of power at wide open throttle I would skip that and go straight to the MAF sensor and check it for dirt. They can be cleaned in most cases.
Kevin.
Old Nov 19, 2002 | 06:15 PM
Xizang11's Avatar
Xizang11
strange how popping the hood and listening to the engine run can lead one right to the loose hose that causes all the problems.....
Old Nov 26, 2002 | 10:16 PM
nobleman's Avatar
nobleman
I'm heading for the dealer at some point, my 2001 Sport Trac occasionally flashes the CES light when I open her up all the way. This is supposedly due to a misfire condition, however, there is no power loss, or hesitation.
It's rumored there's an issue with the fuel pump sending enough fuel... more to come.
Old Apr 30, 2003 | 03:50 PM
nobleman's Avatar
nobleman
Thumbs up fuel system too lean
Yeah, so it turns out that there was a leak in the manifold gasket causing the CES light to blink on hard acceleration. I thought the dealer was full of it, but the light came on once after that for a brief second, as if it forgot the problem was fixed. It hasn't come on since.
Dealer replaced the gasket, ignition wires, spark plugs.
Old Apr 15, 2007 | 11:26 AM
Davnhln25's Avatar
Davnhln25
same problem
I have replaced all 3 02 sensors the ignition coil plugs and wires , then after all that I replaced the coil again and today I am replaceing the 02 sensors (bank 1 and 2 again) see if that does anything I will try the maf sensor too.
