- Camshaft position sensor.
- odd sound when taking off from a dead stop.
- loud shriek from engine
- lifting a 90 ranger 2wd 3-5 inches (the cheap way)
- junkyard axle leaking from front - normal?
- resto diesel Ranger on ebay
- heat control
- HELP!!!!!!!!!!! please
- 2000 Ford Ranger Transmission
- 1995 ranger wont start
- Run Away Idle
- Need some help, wanting to get rims but wanna make sure they will fit
- Bad smell from cowl area into cab
- The One Blink Blinker
- brake woes
- What automatic transmission....
- 2000 ranger shudders once you reach the speed you want
- What's the most mileage you've put on a car or truck?
- 2.9 to 2.3 swap
- Seat hard to slide/tilt
- Touchy transmission kick down
- Door Chime
- Check engine light randomly coming on, mostly on.
- 2.5L quits running
- Ranger hates hills, almost no acceleration in 5th
- B4000, rear axle grinding noise
- Complete noob
- pulley squealing badly
- My 83 Ranger is Gutless up hills
- can someone help!!!
