heat control
Old Feb 24, 2012 | 09:26 AM
mjd2k's Avatar
mjd2k
heat control
Hi, I have a 95 Ranger with a 4l motor.
I cannot control the heat into the cab. Its full heat all the time. My mechanic told me its too hard to deal with and I should just open a window.
He is a really big guy and I think he just does not want to crawl under the dash.
Can anyone tell me where the problem may exist? The **** works.
Thanks very much.
Old Feb 24, 2012 | 02:24 PM
powersmoked's Avatar
powersmoked
Thanks very much.
it's proably the blend door..he is correct the conventional way is to pull the dash.........you can do this method, it explains it . Heater Treater: Blend Door Fix, Heat and A/C Replacement Parts
Old Feb 24, 2012 | 05:12 PM
03 Maz B23's Avatar
03 Maz B23
This link shows the problem and how to fix it.
Heater Blend Door Repair On The 1993-1997 Ford Ranger
Old Feb 24, 2012 | 05:34 PM
bratman2's Avatar
bratman2
Did he drop the glove box down and confirm it wasn't the blend door actuator? That is like $40.00 and a hour labor tops.
Old Feb 25, 2012 | 08:14 AM
Phinxter's Avatar
Phinxter
I should be so lucky to have a guy wanting to give me money to work on such a complex vehicle. sheesh!
Old Apr 17, 2012 | 05:46 PM
mjd2k's Avatar
mjd2k
Even a minutes troubleshooting would have been nice
I went to junkyard and got a new **** control part. No good
Next is see if actuator works
If not.... Then I'll order the part recomended in this thread
Thank you for all the replies! It's still cold up here so heat is not an issue right now
Old Apr 17, 2012 | 09:37 PM
mjd2k's Avatar
mjd2k
Motor works. Now to order part
Old Apr 18, 2012 | 03:59 PM
Phinxter's Avatar
Phinxter
I'll admit working inside a car and tearing out a dash is a pain but seriously you should see some of the crap I have done. One was so dumb the only way to remove 4 bolts to get it out was remove the front doors, thats german engineering for ya
Old Apr 18, 2012 | 11:23 PM
Jeremiahcf's Avatar
Jeremiahcf
I've had the same problem I'm trying to find the way to fix it without taking out your dash. In the meantime if you have a/c turn it to max a/c and that bypasses the blend door and blowes cold air out the vents. I have that web address somewhere I'll post it soon.
Old Apr 19, 2012 | 11:43 PM
mjd2k's Avatar
mjd2k
I kno bout the max AC. I'm sorta **** in that I want it to work properly so I ordered the heater treater part. Already have the motor off and that was a snap.
Will post results just in case some dummy like me has the same problem later!
boatnfish
2009 - 2014 F150
18
Feb 22, 2016 07:58 PM
PStruwing
Oct 28, 2011 06:39 AM
cdestuck
2004 - 2008 F150
Oct 20, 2009 08:52 PM
chasboy
1997 - 2003 F150
Nov 19, 2007 09:13 AM
sundae
Oct 20, 2003 04:57 AM
