- cam phaser timing replacement
- rough country 4 " lift
- Help!!! Passenger Window Problem
- How bad are they???
- 2005 Aviator Intake questions
- A quick and easy oil filter question...
- My 2004 FX4 5.4 has the infamous tick noise :'(
- Anyone really familiar with PATS system (interesting story)
- 5.4 Cam Phasers and Oil Pressure
- Repair Manual
- Ticking Sounds Like a exhaust leak????/
- Coolant Leak 2004 5.4 F-150 Super Crew
- High Mount (3rd) Brake Light
- Easy Maintenance
- Axle seal/bearing questions
- My new old truck, 2006 F-150 60000 miles
- 2004 f150 Heritage INSTRUMENT CLUSTER replacement
- Misc observations after assembling a new mechanically better engine for my truck
- P2006 IMRC Valve replaced allready
- Not downshifting and lugging
- Cranking motor after spark plug change
- Slight vibration when braking...not rotors?
- 2004 f150 5.4. two broken off exhaust manifold studs flush with head
- spark pug removal
- Rough, high idle on an '06 - where is PCV?
- Looking to buy an '04 what should I know?
- Something strange in my transmission pan please help
- cracked manifold great!
- Need Help Deciding between 2 used F-150s
- can I go bigger with radiator??
