Track Bar Removal
Old Oct 9, 2010 | 05:52 PM
Waynenap's Avatar
Waynenap
Track Bar Removal
Being torqued on at 369 ft lbs I would think this is going to be a beast to break loose. Have any suggestions for wrenches to do this job? I'm also wondering if there is a lateral strain, making the bolts hard to remove? If there is, what have you guys done to make it easier?
Thanks for any info.
Old Oct 10, 2010 | 06:01 AM
SSSimon's Avatar
SSSimon
I used a 2'9" breaker bar, 3/4 inch square drive 1 and 3/16 impact socket - and a shed load of grunt. The good thing is that the nut on the back of the bolt has a welded on tab to stop it rotating - so all your energy can go to turning the bolt.
Old Oct 10, 2010 | 08:36 AM
Waynenap's Avatar
Waynenap
Thanks for the info! It looked like it was going to be a bear to break loose. Did you have any trouble getting the bolt out?
Old Oct 10, 2010 | 07:37 PM
th67ss's Avatar
th67ss
How does one re-torque to this 369 ft lbs, I've only seen torque wrenches that go to 250 ft lbs?
I need to replace my bushing in my track bar as well
.....Tom
Old Oct 10, 2010 | 07:46 PM
Waynenap's Avatar
Waynenap
I figure the guys that work on the semi's and equipment, probably have them.
Old Oct 10, 2010 | 08:13 PM
twags6's Avatar
twags6
.....Tom
They make torque multiplier devices specifically for that, but I don't know where to buy or borrow one, or how much it might cost. My brother is gonna hit mine with the 3/4 impact at work when I do the busings and I'll call it tight enough.
EDIT: 185lbs pulling on the very end of a 2 ft long breaker bar would be 370 ft lbs of torque.
Old Oct 10, 2010 | 10:19 PM
th67ss's Avatar
th67ss
That works for me
...Tom
Old Oct 11, 2010 | 05:37 AM
bobbyrjw's Avatar
bobbyrjw
Anyone have a picture of this?
I have read other threads about replacing the front end bushings and no one has mentioned a 369 # torque requirement.
What nut are you referring to?
Old Oct 11, 2010 | 06:19 AM
Waynenap's Avatar
Waynenap
I think your thinking about the sway arm bushings, and this is not it. I don't have a picture of it, but it's about 3' long and in front of the axle and has a bushing on each end that is sandwiched between brackets. One end is attached to the frame and the other, the axle. The bolt head is 1 3/16", I think. I've seen two quotes on the torque requirements, with the last being Clay at Riffraff.
RRRAVEN
Jan 5, 2014 01:26 PM
jskufan
Aug 9, 2013 12:55 AM
Itsmeagain
Sep 23, 2011 08:07 PM
terry2425
Apr 12, 2005 10:16 PM
98BIGBODY
Feb 20, 2003 11:41 PM
