3 on the tree, in a 4x4?
Any way you wanted it
Back in the day ford would put any motor and any trans. and any gear you wanted..Thats why when you are looking for barnfinds..You have to check stuff out carfully..That old wagon could have a 330 or a 427..No telling..You can tell by casting numbers sometimes..But you really dont know for shure till you tear it down...bill
I have a question for this one as I have never seen a 4wd pick up with a 3 on the column. I know the 66-77 bronco had a 3 on the column, but they had a 2 speed transfer case. all 67-72 F-100 4wd's I have seen had a four speed with a single speed transfer case. I was told the thinking behind the one speed transfer case was if the trans. had the granny gear You wouldn't need the low range in the transfer case.
My question is, did the 3 on the column 4wd 67-72 F-100 have a 2 speed transfer case?
reamer
06-10-2017 01:44 AM
socalheel
06-06-2016 10:47 AM
GMbusa
12-14-2015 11:42 AM
7.3stroker2
20
10-24-2015 10:39 PM
jason
10-21-1999 07:23 PM
