No spark/start.
Old Oct 14, 2010 | 08:19 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Originally Posted by alarsso444
Test result after repeatedly measuring, truck side to coil-red wire.
Red/light blue wire: 0.2V in Start(hesitating continuity-ohm meter), 12V in Run
White/light blue wire: 0V in start(continuity-ohm meter), 0V in Run(continuity-ohm meter)
Will get test result of ignition module tomorrow.
Alright, here is one of your problems.
White/Lt. Blue wire should have 12V in run. Not having voltage in run is why it's not starting.
You now need to go in the cab and confirm that you have power coming out of the ignition switch at the Red/Light Green wire with the truck in run.
If you do have power there at the red/light green wire at the ignition switch connector. You then need to check the white/Lt.Blue wire, all the way from the DS-II connector, back into the cab, to where it splices into the Red/Light Green wire between the ignition switch and the resistor. This may involve removing the harness wrapping.
If you do not have power at the Red/Light green wire at the ignition switch connector, ignition switch in run. You need a new ignition switch, or the old one is severly out of adjustment on the column.
Old Oct 15, 2010 | 03:10 AM
alarsso444's Avatar
alarsso444
Thanks again for all help and input.
I will check this up, will probably take some time but I will be back later.
Old Oct 19, 2010 | 01:43 PM
alarsso444's Avatar
alarsso444
Back again.
I left the ignition module at an automotive electrician, for testing., called him today and got the answer that the module is dead.
When byuing a new one, I can get Motorcraft 160 dollars and Standard Motor 80 dollars, here in Sweden, is there a big difference in quality and performance between these two?
I checked the red/light green wire at the ignition switch and there is 12V. Where this wire connects to the ignition switch, the white/light blue wire does too !? This at point 4 for ignition switch (picture) in Haynes wire diagram 81-83 F-series.
Have not followed the red/light green wire to where it splices in to the white/light green wire.
At the truck side connector by the ignition module there is 12V between white/light blue wire and distributer base, in run.
When following the + coil red wire back to connector by ignition switch, it changes color to brown/purple and after some inches further back( in engine room) splits up to brown/purple-pink/white(or tan). This pink/white wire is thicker and softer than the brown/purple and I can't find it in the wiring diagram. Can this be the ballast resistor?
One Sock
Electrical Systems/Wiring
Oct 2, 2024 01:41 PM
BigMightySam5600
37
Nov 28, 2016 06:46 PM
dnkensinger
20
May 29, 2016 06:22 PM
hoytaray
35
Oct 22, 2013 07:03 AM
