Trying to fix bad-running engine
This is going to be a long post, I apologize in advance.
My 84 with 302/2bbl has been running like junk - idles rough, runs rich, very poor power and terrible fuel economy. I've done all I can with adjusting the timing and carburetor, full tune-up, all to no avail. I'm at my wit's end.
I'm now thinking it has to be something electronic. From what I can tell, it's the Duraspark II system so I performed all 17 tests from the shop manual. One result struck me as odd:
Test 8 which is Ig. Mod. to Dist. Stator Assbly Wiring Harness. I guess greater than 70,000 ohms is good. I receive NO reading. I measured this at the connector which plugs into the module. Now I also unplugged the dist. connector and measured for resistance right off the dist. harness and also received nothing.
Correct me if I'm wrong but wouldn't the engine not even run under these conditions?
All other tests checked out except these 4:
Test 4 for Ballast Resistor - I got a reading of 7.2 ohms across the coil terminal BATT and Ignition Module RED where 0.8-1.6 is acceptable BUT, when key in RUN, coil voltage is between 6 & 7 so maybe a bad wire in the harness? I would still like to test coil voltage with the engine running.
Test 10 for Module to Coil Wire resistance - 33,000 ohms (can this be right? it was 33.2 on the 200K scale). Anything greater than 1 ohm says Module should be replaced
Test 14 for Primary Circuit Continuity rendered a reading of 1.1 volts from green wire of module to dist. ground where 1.5 volts or less says replace module. When I disconnect 4 wire connector at module and measure voltage of green wire coming from tach, I get full battery voltage.
Test 15 for Ground Circuit Continuity rendered a reading of 0.1V where 0.5 volts or less says replace module
So I hate throwing parts at things and hope it fixes the problem. All roads point to the ignition module but my question is: CAN THE ENGINE STILL RUN WITH A BAD MODULE?
Also, my coil primary resistance is 1.6 ohms which is right at the max so I don't know if I should just replace that too?
There can be "bad" parts that will run, but go intermittent when hot, etc.
Is there a fat blue spark at the plugs, that snaps in the air? Orange is no good. That's what matters.
NumberDummy has often described the classic symptoms of a failing ignition module here:
- Engine dies, can be restarted almost immediately.
- Engine dies, can be restarted in a few hours.
- Engine dies, will not restart.
Is a failing module "bad" or not?
For example your first question; What are they testing? Shorts to ground? If so, then a infinity or "no reading" would be excellent.
If the tests say the module is marginal replace it and do the tests again.
Wonky readings could be a loose lead in your meter, or maybe it just needs fresh batteries?
Really high or infinite readings on harness sections would have me cleaning connections.
What reading do you get for the distributor pickup? (across the orange and purple wires at the distributor connector)
What reading do you get for the coil secondary winding?
Actually only parts so far was tune-up and it needed it bad- ran much worse before. Lately it's just been trying to tune by adjusting timing and carb.
As for the coil, it checks out - Primary resistance 1.6 ohms, secondary is 9,880 ohms
A lot of people on the forum say "only Motorcraft" but I use an Echlin TP40 module.
Sometimes the reading is okay with the coil cold and it fails when hot.
if you have a spare sparkplug make sure it is gapped close to .044" and use the #2 plug wire so you can easily see it while jumping the starter.
Ok, I will try this and see what I come up with. I am buying a module today (BWD), NAPA had nothing in stock until Tuesday and I'm going to get an Accel coil just in case. I'm also going to clean up as many of the connections as possible. Some seem a little corroded, especially the coil terminals which gave me an off-the-charts reading when connected to the coil but when I tested the coil by itself, it was fine.
I think I'm looking at a failed ballast resistor... I have the new ignition module but I don't want to install it for fear of the higher voltages frying the thing.
Thoughts?
Upon further testing, I may be looking at a faulty stator assembly. I get the correct resistance across the orange & purple wires but I am also getting some resistance between the black lead and engine ground, which according to two sources should be no resistance. Also according to two sources, there should be resistance between orange and ground and purple and ground and I get nothing. This, based on the test procedure, would say the pickup assembly is bad. But again I'm dumbfounded - could a pickup test bad but still allow the engine to run, albeit poorly?
I'm seriously just tempted to get a points distributor and throw it in and call it a day. I don't have much patience for this "computer-controlled" stuff.
