Sponsored by: Auxito
Suspension problems please help
Old Oct 4, 2010 | 09:36 PM
FORDorNothing12's Avatar
FORDorNothing12
I have a 2002 F-150 4.6L 4wd ext. cab and I recently found out that my ball joint in the front left wheel. I know this needs to be replaced but I wast told that the only way to replace the joint is to replace the control arm. Which arm do I need to replace lower or upper.Aslo if there is any possibility to tell me the part number. I would also like some good sites to price out theses parts.
Old Oct 4, 2010 | 09:43 PM
steve(ill)'s Avatar
steve(ill)
lower joint can be pressed into the A frame. $40 for MOOG at most places. THe upper ball comes with the A frame. normally about $80. for that.
Old Oct 4, 2010 | 09:49 PM
FORDorNothing12
so if i were to replace anything it would be the lower control?
Old Oct 4, 2010 | 10:02 PM
steve(ill)'s Avatar
steve(ill)
no, the lower arms are o.k., you press out the ball joint and press in a new one. most will wear out in 20k miles. If you want a good one buy MOOG... the upper ball is part of the A frame. you replace the ball and the A frame as a unit.
1997-2002 Ford Expedition Ball Joint LOWER (MOOG): eBay Motors (item 130438969135 end time Oct-06-10 13:07:49 PDT)
Old Oct 4, 2010 | 10:33 PM
93 mix 'n match's Avatar
93 mix 'n match
heres what ya need
snap ring pliers, assorted sockets and wrenches, pickle fork, balljoint press.
EDIT and a grease gun, and a big socket for the hub nut.
Old Oct 4, 2010 | 10:37 PM
93 mix 'n match
as far as balljoints, go MOOG. best ***** on the market and buy from rockauto.com. best place for parts.
lower/upper
Lower
Upper
Old Oct 5, 2010 | 07:55 AM
SteevenH's Avatar
SteevenH
Everyone is right ! I know I'm in the minority but I figure while I'm at it , it's not that much more work or money to replace the lower a-frame bushings. The uppers are new, why shouldn't the lowers be also. I know alot of people say they don't get much wear. I just figure that that bolt running through the center has to do some damage as many times as the arm pivots up and down. But that's just me. lol
P.S. Definitly use MOOG parts.
Old Oct 5, 2010 | 09:34 PM
FORDorNothing12
Thanks for the info guys. Its helped alot
Moto7387
1997 - 2003 F150
Nov 13, 2010 07:28 PM
eallanboggs
Feb 23, 2008 09:41 PM
SproutW
Dec 29, 2007 09:38 PM
billj6
1983 - 2012 Ranger & B-Series
May 18, 2006 05:06 PM
Zcarbuilder
Aug 21, 2004 09:20 AM
