Lower Control Arm Bushings
Old Dec 29, 2007 | 12:33 AM
SproutW's Avatar
SproutW
Well it's time to replace the ball joints on my 2002 Expy 4x4. Figured I would replace the control arm bushings as well. The manual states the lower control arm bushings may be welded on, if not the bushings will need to be replaced by a shop. Anyone replace the lower control arm bushings before? I'm sure they are pressed on but can the ordinary mechanic replace them without a press? Any further tips for replacing the ball joints. I plan on using all Moog parts.
Old Dec 29, 2007 | 09:38 PM
devildogmech's Avatar
devildogmech
I have seen it done with a realy big C-Clamp..... I have a shop down the street that will press items for $10 each... Every where else wants 1hr of labor for each part ($98 per hr!)! If you can find a good shop like that, take the LCA's off and take the parts in and have them do it for you. If not, an arbor press is only about $200 for a cheap model and might be worth the investment if you plan on doing further home auto repair work. If I hade the $200 I'd buy the press...
JMHO
Billy
mattbuxton87
1997 - 2003 F150
Feb 27, 2013 05:21 AM
Moto7387
1997 - 2003 F150
Nov 13, 2010 07:28 PM
jimkari
Mar 8, 2008 10:02 PM
eallanboggs
Feb 23, 2008 09:41 PM
twallace
Sep 15, 2004 03:10 PM
