e4od problem
Old Oct 4, 2010 | 11:19 AM
phantom 309's Avatar
phantom 309
e4od problem
i have a 93 ford diesel with e4od tranny seems to slip in 3rd gear and overdrive could it be my tranny filter no codes r showing either
Old Oct 4, 2010 | 07:30 PM
David85's Avatar
David85
How many miles? When did this start?
Old Oct 4, 2010 | 09:43 PM
phantom 309
230,000 recently
Old Oct 4, 2010 | 10:34 PM
David85's Avatar
David85
Slipping in 3rd and 4th doesn't happen very often at the same time but I'm wondering if its the torque converter clutch not engaging in 3rd and 4th that you are noticing.
Are the gears simply slipping only during the upshift, or will they slip under load after already in 3rd or 4th for a prolonged period of time?
Does operating temperature affect it at all?
Strange that it isn't throwing anything at you. This should normally put the trans in limp mode and allow a code retrieval.
Are there any recent changes you made to the truck or any servicing done? The more info the better even if it seems unrelated.
You could try chainging the fluid and filter if that hasn't been done within the last 50k miles. You can check the pan at the same time for metalic debris or black deposites coating the pan and exposed valve body (indicates fine metal shavings). Anything like that found in the pan and consider yourself warned that you are on borrowed time.
Old Oct 5, 2010 | 08:31 PM
phantom 309
i changed the filter n fluid its not doin it ne more but i had a little bit of grey matter on the magnet
Old Oct 5, 2010 | 08:55 PM
grams72's Avatar
grams72
Earlier this spring I also had some trans slippage issues, I used a lucas trans product and I believe it actually helped....
Old Oct 5, 2010 | 09:08 PM
David85's Avatar
David85
Some grey stuff on the magnet is normal - thats why its there. Hope that solves the problem.
Old Oct 6, 2010 | 10:59 AM
joelswork's Avatar
joelswork
sounds familiar! Check out my posts on the e4od...burnt up on me but I still don't know the cause. Just spent $2000 on a tranny rebuild and it went back to the shop the same night. Now it has the abs light and the brake light on. Slipping around 30-40 mph...kinda searching for what gear it should be in
I'll keep you posted as I hear from the shop!
papajunk
Jan 3, 2011 08:48 PM
slowr w/o blowr
1997 - 2003 F150
Feb 14, 2008 02:47 AM
padutch
May 20, 2002 09:26 PM
adelyser
1978 - 1996 Big Bronco
Mar 5, 2002 01:00 AM
trcklvngrl
May 14, 2001 10:29 PM
