Highboy Information Compilation
Old Oct 4, 2010 | 10:11 AM
  #31
Blown 331's Avatar
Blown 331
Originally Posted by zerfetzen
# Lowboy #
All F-250 4x4's after 1977.5 (specifically, beginning in March 1977) are
considered "Lowboys". The weaker married transfer case (NP203) replaced
the stronger divorced transfer case (NP205)
A married NP205 was used until 1979. The NP203 is full time and not all 77.5-79s are full time. So I don't think saying a lowboy has a weaker transfer case than a highboy would be correct since either comes with an NP203 or NP205.
Old Oct 4, 2010 | 10:37 AM
  #32
zerfetzen's Avatar
zerfetzen
Thanks for pointing that out, I thought all NP205's were divorced, and didn't know they continued until 1979. I'll change that now.
Old Oct 6, 2010 | 05:10 PM
  #33
zerfetzen's Avatar
zerfetzen
There is a lot of new information here, but the biggest changes regard frame information and overall height comparisons (in the suspension section), both with sources listed. Most other sections have received small updates.
I'm surprised to see that in 1970, the Highboy was as much as 6.4 inches higher than a F-100!
Old Oct 7, 2010 | 06:21 AM
  #34
1976HighBoy's Avatar
1976HighBoy
Zerfetzen, FANTASTIC post, I think you have put the most complete post on the Highboy as there has ever been on FTE. Regardless of what other may ridicule you about, or try to contest any of your info, for what it's worth-AWESOME JOB!!!!! I am going to copy your entire post X10 and hand them out on the Fridays when everyone cruises there old trucks and talks about there F150 Highboys with a factory 4 inch lift. It amazes how many of these trucks are still on the road and running and going strong and still uneducated some individuals are. I don't claim to be an expert on the 67 to 77.5 F250 4x4 variety of ford trucks, but I know a hell of alot more thanks to you my friend. Keep up the good work. All your research and time posting is much appreciated.
Old Oct 7, 2010 | 01:55 PM
  #35
zerfetzen's Avatar
zerfetzen
That's a nice looking rig as your avatar, 1976HighBoy.
For Ford lovers...
I posted another update this morning that compares F-250 (whether 4x2 or 4x4) frame strength to a 70's Dodge W200 and Chevy K20. There was no dentside F-250 with a frame as weak as those examples.
I'd like to find more info on their frames. Ford 3/4-tons didn't have anything that weak at the time. Now I wonder what their strongest was?
All of this assumes an equal frame yield strength of 36,000 PSI, which may or may not be right across brands.
And I know that for a 10% increase in wheelbase, a 10% increase in section modulus must accompany for the rig to handle the same load, so wheelbase counts too.
Interesting though...
Old Oct 7, 2010 | 02:21 PM
  #36
doug70's Avatar
doug70
Great post
I don't have a highboy, but think it is great to have all this available in a single post. Mine is a 79 F250 Frame. I learned something about the frame widths and beds that i didn't know. I had planned on how to make some brackets to mount my 73 bed on the 79 frame, but because it was a 2WD and the 77.5+ are the same pattern, it saved me some work.
Doug
Old Oct 29, 2010 | 10:35 AM
  #37
Blown 331's Avatar
Blown 331
A link to this thread has been added to post #8 of the FAQ, tips and tricks sticky which discusses highboys and already contains links to other highboy threads.
https://www.ford-trucks.com/forums/1...ml#post1437578
Old Oct 31, 2010 | 08:20 AM
  #38
dragracer1956's Avatar
dragracer1956
I'm new to the forum,and i'm a little confused about the term regular cab on the hi-boys.I bought a 1976 off the original owner y26--------- this truck has all the goodies meaning hi pile carpet ranger xlt badges mouldings on the bottom of cab and bed, side box sliding rear window 360 -205-dana 60-44 4-speed this truck is all original right down to the lug nuts.Nothing was ever added and this is the way it left the showroom.My question is what do they consider a regular cab on a 76 hi-boy.Thanks Craig
Old Oct 31, 2010 | 08:37 AM
  #39
zerfetzen's Avatar
zerfetzen
Welcome to the forum. There are three types of cabs in this generation of F-series trucks: regular cab, super cab, and crew cab. So the regular cab is a two-door cab that is not extended behind the backseat.
Old Oct 31, 2010 | 08:05 PM
  #40
lasthighboy's Avatar
lasthighboy
I think this would also be good as a sticky, due to the volume of questions about highboys and the amount of information compiled here. Yes it has been covered before, and yes there is a sticky on it already, but it is buried under another title. If it was a sticky with its own title, maybe more people would notice and read it, and possibly eliminate some of the redundant questions.
I have never figured out why the highboys used a narrower frame, other than possibly to use up leftover frames from the previous eras. I dont believe it has anything to do with accomodating a divorced transfer case, I dont see what differece that would make.
I do believe all dentside frames are the same width in front, the highboy frames run straight back and the others widen out just behind the cab. Its easy to see if you look at the frame from the rear, especially with the bed off.
Fenderwell exit headers should fit the same for any truck. I dont know of headers being different for highboys. I have noticed chassis exit headers are not available for manual trucks, only for automatics. I believe this is due to the clutch linkage being in the way.
Old Oct 31, 2010 | 08:09 PM
  #41
Blown 331's Avatar
Blown 331
I have the L&L fenderwell exit headers on my 1977 F-150 4x4 4 speed. Its not a highboy but as far as I know the clutch linkage is all the same, so if it clears my clutch linkage it should clear all models.
Old Oct 31, 2010 | 08:59 PM
  #42
lasthighboy
Yes, the fender exits do. I said the chassis exits dont work with clutch linkage.
Old Oct 31, 2010 | 09:04 PM
  #43
Blown 331's Avatar
Blown 331
Ah, my mistake. I mis-read that.
Old Nov 1, 2010 | 06:12 AM
  #44
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I bought a 1976 off the original owner y26. This truck has all the goodies meaning hi pile carpet ranger xlt badges mouldings on the bottom of cab and bed, side box sliding rear window 360 -205-dana 60-44 4-speed this truck is all original right down to the lug nuts.Nothing was ever added and this is the way it left the showroom.My question is what do they consider a regular cab on a 76 hi-boy.Thanks Craig
Welcome to FTE
All 1967/76 F250 4WD's are refered to as High Boys, have a divorced transfer case.
1977 F250 4WD:
Before serial number Y20,001 = High Boy
From serial number Y20,001 = Not a High Boy. Has a married transfer case.
High Boy's were not available as a Super Cab. Only as Regular & Crew Cabs as a Cab & Chassis or with a Styleside or Flareside bed.
But, if Y26 refers the first three digits of the six digit serial number, the truck is a 1977, not a 1976. It will not be a High Boy and will have a 351M or 400 engine, not a 360.
1976 serial number range: A00,001 thru D25,000 / The serial number is the last 6 digits of the VIN / 360 = 5 valve cover bolt holes per side / 351M/400 = 8 valve cover bolt holes per side.
No 360 engines in F100/350's after 1976.
All 1973/79 F100/350's have rear frame rails that are 37 1/2" apart > EXCEPT < the following:
1973/77 F250 4WD (High Boys) / 1973/79 F350's on the 140" wheelbase. All these trucks have rear frame rails that are 33 1/2" apart.
Old Nov 2, 2010 | 07:14 AM
  #45
dragracer1956
1976 hi-boy ??
I screwed up ,my serial# f26yca3041 not y26 and the frame on the passenger side next to the engine crossmember has the same number stamped on the top rail flange it has the 33 1/2 in rail,sorry about that.Do i have a hi-boy or is this thing a piece together? Thanks for the help you and the rest of the members are a wealth of knowledge Thank you
