has anyone else had problems using superchip flaspaq and transmission shifting weird between 1 and 2. I replaced the trans filter and changed the fluid in it today and shifted fine, then put in the superchip to fuel saving and it started to mess up again.
i have a superchips flashpaq as well, i bought it this spring. i haven't had problems with 1 and 2 but 3 and 4 give me some trouble when it's near wide open in Heavy Tow mode. the transmission is "hunting". have you gotten online and had your tuner recalibrated? i believe the tuners programming just needs to be fine tuned. unfortunatley i can't get online and recalibrate mine due to some computer error. Sorry i'm not much help but i just wanted to let you know my thoughts and share my problem with the tuner. i know it was the tuner though, when switched to max performance or any other program it's fine.
I ran a Superchip from '03 to '07 and I didn't have any problems, untill I got a DP-TUNER. I thought the Superchip was the bong, but the DP-TUNER is hands down better in every way.
The Bong..I'm with Rick, I had the 1705 and had zero problems with mine and I thought it was the Bomb, lol..One thing I can add, when I dropped my trans pan to put in my VB, not sure whats normal clutch dust debri but it was all over my magnetic pan bolt. I didn't take pics to compare with others here. Sounds like its time for some custom tunes. If your SC tuner reads codes I'd advise you hold onto it, I did, its great for that..
