Pulled the switch today
Old Oct 1, 2010 | 06:02 PM
jowilker's Avatar
jowilker
I pulled the ignition switch today thinking I would clean the wiring connected to it, WRONG
About 4 wires connected to the center post and everything else behind the wall sealed up.
No cleaning allowed.
John
Old Oct 1, 2010 | 08:42 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
John, I don't know which ignition switch you have, as there are two possibles.
1961/66: The original switch (C3AZ11572A-Auto-Lite SW353) had three connectors.
In 1967, Ford obsoleted this switch, replaced it with another (C7UZ11572A~Auto-Lite/Motorcraft SW583)) that has four connectors for use as a service part replacement.
The C3AZ11572A switch was also used on 1960/64 Passenger Cars, 1965 Falcon/Fairlane, 1965/66 Mustang and 1966 Bronco.
The 1961/66 replacement switch (C7UZ11572A) is correct for 1967 Econolines & 1967/77 Bronco's.
The bezel, ignition cylinder and other ignition switch attaching parts are the same for either switch.
Old Oct 1, 2010 | 08:50 PM
jowilker's Avatar
jowilker
Bill are there any images anywhere. I was thinking there were 4 wires that went inside through the wall and 4 others on the post. I can verify tomorrow.
John
Old Oct 1, 2010 | 08:56 PM
NumberDummy
Sorry, John I have no shop manuals or wiring diagrams....and the ones in the parts catalogs are useless.
Since the same 4 connector switch was used in 1967/77 Bronco's, a wiring diagram for one of those can be used.
Dunno if Bronco Graveyard has any or not.
Old Oct 1, 2010 | 10:15 PM
hollygreenman's Avatar
hollygreenman
I just ordered Osborn wiring diagram today. If you still need it when I receive it, I'd be happy to share it.
Old Oct 2, 2010 | 05:54 AM
jowilker's Avatar
jowilker
I just Googeled 1966 Ford Ignition switch, then images on the side bar.
This one resembles my switch The red arrows were there.
This replacement one at Advance Auto looks close too. Advance Auto Parts: Ignition Starter Switch by BWD - Part CS52
Bill, I posted resembles, not is correct, just for you.
I can go back later and take a photo, also can take the nut off the center to expose the wires in the wall.
John
Old Oct 2, 2010 | 02:02 PM
jowilker's Avatar
jowilker
Took a photo of the switch still in place, what can you tell if anything?
John
GM4WALLS
Nov 5, 2014 07:54 PM
Snowking
Jul 20, 2010 07:32 PM
krankshaft
Aerostar
Aug 23, 2009 11:19 AM
Jaws0705
13
Jul 15, 2005 10:07 AM
jjlrrw
1997 - 2003 F150
May 16, 2005 12:41 PM
