Aerostar Ford Aerostar
Parking Brake Light Switch
Old Sep 26, 2005 | 08:35 PM
krankshaft's Avatar
krankshaft
Well my Aero is giving me trouble again it seems that that when the parking brake is pulled up the light isn't coming on at all. This has happened before but the light came back on after repeatedly pulling the parking brake up and pushing it down.
I'm thinking the switch is shot or needs cleaning if possible but before I look into it how is the switch wired?
Is it wired like on one of my car's the switch connects and disconnects the parking brake indicators ground to turn it on and off or does the switch actually connect and disconnect the hot lead?
Old Sep 26, 2005 | 08:54 PM
ken1mod's Avatar
ken1mod
I don't know how it is wired but mine responded to a good wd40 soaking without removing anything. it really gets filthy down there. works good now.
Ken
Old Sep 26, 2005 | 09:53 PM
copper_90680's Avatar
copper_90680
Krankshaft:
It's just a simple on/off push button switch, but unbelievably cheap one.It consists of a spring and a contact, all exposed, not sealed. The connector probably costs 100 times that switch. I don't think it's even made in China. Even China makes better stuff than that
Old Sep 26, 2005 | 10:03 PM
krankshaft's Avatar
krankshaft
I noticed I have never seen such a simple switch and leaving it exposed causes even more trouble.
Upon further inspection this is a ground switch the switches mechanics are simple in nature there is a pin with a washer at the bottom when the parking brake is pulled up this washer is pulled up by the pin connected to the spring against 2 contacts one comes from the ground wire from the indicator light and the other connects the switch to the metal of the parking brake (ground).
When the parking brake is pushed down the pin gets pushed down against the spring causing the washer to move downward away from the contacts thus breaking ground and turning the indicator light off.
Just to be safe I removed the switch and sanded all the contacts including the clip that holds the bolt in and the metal behind the screw on the other side of the switch that contacts the brake then I put white lithium grease on both the spring on the pin and the inner contacts to prevent any rusting or sticking in the future. Probably the washer was getting stuck causing the switch not to work but the grease fixed that. Reassembled and everything works great .
Old Aug 23, 2009 | 11:19 AM
93nighthawk's Avatar
93nighthawk
Thanks for the info Krank!
I know what todays Aero-Restro project is.
Bluey Zedoff
Jan 29, 2016 05:14 AM
Todd Fuller
May 22, 2015 09:59 AM
knash0727
Dec 23, 2014 11:15 AM
hwyhogg
15
Dec 8, 2014 08:15 PM
fp_5
1997 - 2003 F150
May 8, 2009 05:13 PM
