Sponsored by: Real Truck
HELP powerstroke 6.0L trouble
Old Sep 30, 2010 | 04:53 PM
06f3506.0's Avatar
06f3506.0
hey guys im new here and to ford in general. 171500 miles the motor blew and we replaced it with a 30,000 mile motor from a wrecked truck here enlies the problem. we put the egr delete on which is good for the motor BUT i think before the old motor blew the map had a problem so today i changed it and i get the codes for the turbo under boost and the map and also the exhaust pressure codes. i have not pulled the exhaust pressure out to clean or the turbo sensor. when warm it will be like there is no turbo then i put it in N and shut it down then start it back up then i have a turbo.. any wisdom is greatly appreciated.
Old Sep 30, 2010 | 05:02 PM
gearloose1's Avatar
gearloose1
1. go to 6.0 tech folder and look up your problem.
2. I can't see what your problem is...
Do you have any codes?
Old Sep 30, 2010 | 06:47 PM
06f3506.0's Avatar
06f3506.0
ok maybe i wasnt clear enough i have a new map sensor and i keep getting the map code p0069 the exhuast pressure circut code p0470 and the turbo under boost code. and sometimes when the truck is warm and i start it and leave the turbo will not spool but if i put it in neutral and restart it the turbo will work .. i hope thats clear enough
Old Sep 30, 2010 | 07:22 PM
gearloose1's Avatar
gearloose1
Is the EGR valve new? Clean plenum?
Old Sep 30, 2010 | 07:34 PM
06f3506.0's Avatar
06f3506.0
i have the egr delete kit on it. and the only code i should recieve is directed toward the egr on that but i dont have that code i have a chip to bypass that.
Old Oct 1, 2010 | 09:31 AM
Scottwoo's Avatar
Scottwoo
Mine is doing the exact same thing...I dont have the EGR delete though. Been dealing with this and Ford for a month now. They have no idea what is wrong. New EGR Valve, VGT valve, new turbo, new MAP...same problem!!!
Old Oct 1, 2010 | 09:40 AM
gearloose1's Avatar
gearloose1
Scottwoo
1. go over to 6.0 forum to discuss.
2. I have a simple fix for you to try.
I tend not to get into modded / chipped / EGR deleted vehicles.. too many variables.
Rods&Rides
EcoBoost (all engine sizes)
Dec 14, 2015 07:24 PM
thahn1608
Jun 12, 2015 10:23 AM
TedHJ
Jun 11, 2015 11:26 AM
ruschracing4
May 17, 2015 01:01 PM
dpassarella
Mar 30, 2014 07:55 PM
