exhaust back pressure line problems
Old May 13, 2015 | 01:50 PM
ruschracing4's Avatar
ruschracing4
I have a 1995 ford f250 7.3 diesel and I have just found out the line to my exhaust back pressure sensor is broken and my SOLUS Ultra snap on scanner say my exhaust back pressure is at 14.9 psi how can this be also at idle the ebp is at 14.9 along with the map sensor at 14.9 but when I'm driving and speed up the map sensor go's up to 25.7 is my exhaust back pressure sensor stuck or something not to good with diesels here also I should add when the vehical is off and key is one exhaust back pressure is still 14.9 and map psi is 14.0
Old May 13, 2015 | 02:23 PM
Hussler's Avatar
Hussler
The exhaust back pressure sensor is broken, the PCM knows it so it's defaulting to a default value.
Old May 13, 2015 | 03:25 PM
ruschracing4
Alright cool thanks for the quick reply I got a new one ordered!!!
Old May 16, 2015 | 01:26 AM
Airstreamer67's Avatar
Airstreamer67
It sounds like the values initially may be showing the atmospheric pressure, and the engine's operation is adding to that.
Old May 16, 2015 | 04:41 PM
madpogue's Avatar
madpogue
^^^^ Hint - what does the A in MAP stand for?
The EBP sensor is probably fine. You would expect it not to go up if the pipe to it broken.
Old May 17, 2015 | 09:44 AM
oldbird1965's Avatar
oldbird1965
I think Riffraff sells the pipes.
Old May 17, 2015 | 10:11 AM
ruschracing4
Ok so I have a new ebp sensor and it still reads 14 psi continously my map sensor still reads 14.9 but I also have no codes I have done all the tests and eveything only code I have is for the butterfly valve on the back of the turbo I just have it stuck open what's my problem is. Should my map and ebp read 1 or 2 at idle usually? I'm not the best with diesels
Old May 17, 2015 | 11:18 AM
madpogue's Avatar
madpogue
Is the pipe to the EBP sensor still broken? Is it clogged? If yes to either, then a perfectly good sensor (and your old one probably was) will STILL not read above atmospheric, or at best only slightly above.
Does the MAP sensor reading go up when you drive the truck under some load? Not just revving it up in the driveway, but actually on the road, making a demand of the engine.
What does your BARO sensor read?
Old May 17, 2015 | 01:01 PM
echo95's Avatar
echo95
Your original sensor was good as it was reading the atmospheric pressure at the time. Default if the sensor is bad and connected is around 52.9 psi if the ECU senses the MAP and EBPS far apart. The ECU will not operate the EBPV under those conditions.
EBPS will usually read a tad higher than MAP. Mine is currently disconnected as I have no EBPV any more. Reads around 42 psi with it disconnected according to torque pro. No affect on engine performance that I can tell.
Faster71
Feb 23, 2014 05:57 PM
drs041
Jan 28, 2014 04:01 PM
Mark525
Aug 18, 2009 03:14 PM
bloomy63
Dec 7, 2006 08:07 PM
