3 on the tree 3rd gear problems
Old Sep 28, 2010 | 06:14 PM
the bird's Avatar
the bird
i have a 1964 ford f100 with three on the transmission but every time i put it in third gear it will either go in smoothly and pop out into nutral or it will grind in to third gear and still pop out. ive been trying to find what the problem is all over the internet but i cant find anything so if i cant find out why can i put a 4 or 5 speed in it it is a 292 V8.
Old Sep 28, 2010 | 07:46 PM
creich68's Avatar
creich68
Maybe a bad synchro but you'll have much better luck posting in the f100 section. Just a friendly reminder that's all.
EDIT: here's where you want to post. these guys will be helpful : https://www.ford-trucks.com/forums/forum40/
Old Sep 28, 2010 | 11:52 PM
Racerguy's Avatar
Racerguy
Welcome to FTE
I've moved your question down to the forum that creich68 mentioned.
Good luck with it.
Old Sep 29, 2010 | 12:23 AM
Broomfieldbum's Avatar
Broomfieldbum
I haven't had these issues in years. I used to see this type of thing all the time with my 64 Econoline. I have heard on the slicks that either bad bushings in the linkage, or rotting(collapsing) cab supports can cause all sorts of shifting issues.
On your want to put a 5 speed in HOME T The only issue I heard about the t-5 Mustang transmission is that the shift point is way back, and so you will have to build a creative shifter because it comes through the floor under the seat.
Old Sep 29, 2010 | 12:40 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Popping out of 3rd gear:
The two 2nd/3rd syncronizer brass blocker rings are worn.
jgavac
Jan 24, 2013 10:50 PM
F1001964
May 24, 2012 02:04 PM
RangerXLT75
Apr 2, 2012 10:00 AM
bookpile
Sep 25, 2011 09:19 PM
Wingnutt
Oct 13, 2003 09:05 PM
