Sponsored by: Real Truck
better ball joints
Old Sep 28, 2010 | 07:13 AM
mrsautox's Avatar
mrsautox
better ball joints
I have a 2007 E-450 class C rv and the ball joints are going at 40k. I know Ford is not know for their quality.
What brand do you guys suggest for lasting?
Thanks,
Donna
Old Sep 28, 2010 | 07:31 AM
gearloose1's Avatar
gearloose1
LOL... what is known for their quality?
No questions asked eBay parts?
Old Sep 28, 2010 | 09:04 AM
mrsautox's Avatar
mrsautox
Ford does not believe in adding grease fittings to ther ball joints, meaning they don't last.
Old Sep 28, 2010 | 09:33 AM
cartmanea's Avatar
cartmanea
I used Moog greaseable ball joints on my '03 and they seem to be holding up well. Ford does have some greaseable joints available, but I'm sure they cost more than Moogs.
Old Sep 28, 2010 | 09:43 AM
GUNNERDOG's Avatar
GUNNERDOG
I have heard people have had good luck with moogs. I installed them on one side and so far so good, but too early to tell.
Old Sep 28, 2010 | 09:45 AM
KhanTyranitar's Avatar
KhanTyranitar
Moog is the only way to go. The Ford ones are better than most aftermarket brands, only the Moogs have been engineered to outlast OEM.
Old Sep 28, 2010 | 09:58 AM
gearloose1's Avatar
gearloose1
If you want greaseable joints, OEM Moog replacements are the way to go.
I modded my ball joint to add grease fittings...
Old Sep 28, 2010 | 10:00 AM
gearloose1's Avatar
gearloose1
Oh.. since you are running an RV.
Share with us some details.
What is the GVWR of the chassis?
What is the "unladened" weight with gas, full, water and propane full, holding tanks empty?
What is the actual "drive away weight" when you are actually using it?
If I were to guess --- you have an overload problem that is contributing to early failure.
It is highly improbable that 40,000 miles will be enough to wear out ball joints on a 450 (factory greased) unless there are other factors.
I have seen cases of premature wear, but these are vehicles doing rough work --- snow plowing, heavy hauling, 4 wheeling, or the joints have been immensed in water --- like by crossing a stream, or constant use on rough (dirt with lots of holes) roads.
On pavement, with average loads, ball joints should be pushing 70,000 miles.
There was a problem with ball joint quality on the E series back in the early 90s, but that is a long time ago.
Old Sep 28, 2010 | 10:50 AM
redford's Avatar
redford
FTE Leadership Emeritus
Moog. You may have to run without the grease fittings, as they may hit other parts as the suspension moves. You screw in the grease fittings when you need to regrease the ball joint.
Old Sep 28, 2010 | 10:56 AM
Parts Jimmy's Avatar
Parts Jimmy
Lets see. Ford ball joints...............poor quality? I just replaced my F350's ball joints with 255k miles on them.
I would say that Ford's ball joints are probably the best quality.
Blueheart
Dec 22, 2011 06:41 PM
sweetsride
Apr 23, 2010 05:12 AM
kottondog
Nov 10, 2007 08:26 PM
Badford
Feb 19, 2005 01:06 PM
ssls6
Jan 20, 2004 08:51 PM
