Disc conversion--IMPORTANT INFO!!
Old Sep 29, 2010 | 09:46 PM
F-250 restorer's Avatar
F-250 restorer
Originally Posted by Thunderjet4x4
Interesting and good info! Happen to have a pic of the E-brake arm-unassembled, and how it keys in?
The shaft in my hand is the ebrake shaft assembly shaft. It goes thru the back of the caliper housing, and the ebrake lever has a 6-8? sided hole that fits right over that 9/16" 'nut' (left side in photo) on the shaft. To adjust the caliper you ratchet the arm back and forth until you only have 1/4" --1/2" travel. Before the lines are connected.
<a href="http://s659.photobucket.com/albums/uu316/bobbyrogue/?action=view&current=P1010392.jpg" target="_blank"><img src="http://i659.photobucket.com/albums/uu316/bobbyrogue/P1010392.jpg" border="0" alt="Photobucket"></a>
In the photo below, the groove at my thumb is where the ebrake seal rides.
<a href="http://s659.photobucket.com/albums/uu316/bobbyrogue/?action=view&current=P1010391.jpg" target="_blank"><img src="http://i659.photobucket.com/albums/uu316/bobbyrogue/P1010391.jpg" border="0" alt="Photobucket"></a>
Old Sep 30, 2010 | 08:13 PM
Thunderjet4x4's Avatar
Thunderjet4x4
Ahh, thankyou very much! These calipers have a some quirks, but once figured out=cake!
The calipers look pretty simple-compared to some parts-like an auto trans or whatever.
Keep up the good work F-250 restorer
Old Oct 1, 2010 | 12:30 AM
F-250 restorer
I'm not sure I needed to become an expert on these calipers. I guess the most valuable lesson here is that a person doesn't have to search high and low for the 76--78 el dorado calipers. Anyone can pull the big GM calipers from a seville or fleetwood, and swap out the pistons if you need to. That is good to know since the dodo calipers are getting extremely hard to find.
I guess it was good to learn all that I was forced to learn before I installed them incorrectly. I'm sure that had I done that, I would have thought them crap like everyone else who installs them wrong.
If this post helps others, then it is worthwhile.
KRH
Old Oct 6, 2010 | 08:58 PM
F-250 restorer
I found that TSM makes a tubular bracket which should adapt the oem ebrake cables to these calipers.
Since I'm banned from the local pick-your-parts for taking a hammer and pry bar to their water machine (selling ice, not water on a flaming hot day and refusing to refund my $) it's a bit more diff. to snoop for parts.
Old Oct 23, 2010 | 04:37 PM
F-250 restorer
Ebay brackets
I bought the caliper brackets on ebay from Great .... 4X4. They look like he just cut them with a shaking lazor, drilled and tapped the holes, and shipped. No grinding of sharp edges, no paint. They look like 'high school shop' time.
acamk37
Feb 19, 2015 11:05 AM
bobbytnm
57
Jul 26, 2011 08:00 PM
F-250 restorer
Oct 30, 2010 09:30 AM
smlford
Jul 4, 2009 05:49 PM
