Build list for our trucks
Ladies and Gents,
We've had several great threads lately about shop tools, shop pics, junk yard finds, etc. Here's another one. How about everyone tossing out a basic list of what they've done to their trucks, similar to the build sheets you see in some magazine articles.
Here's a bare bones list of things on my truck;
1949 Ford F1
CHASSIS:
Frame manufacturer: 1949 Ford,
Modifications: 1972 Caddy trans x-member, boxed front by me, rear x-members by me, engine mounts by me, tranny mount by me
Rear-end/Ratio: 1960 9” Ford, 4.11??
Rear suspension: stock
Rear brakes: 1960 Ford drum with 1969 self adjusters
Front suspension: stock with several leaves removed
Front brakes: ECI disc conversion, 79 F-150 rotors and inner bearings, 72 Caddy calipers, 74 Monte Carlo outer bearings, 69 Buick rubber brake hoses
Master cylinder: 1981 Caddy with late 1990’s Ford Focus power booster, Jegs line lock solenoid, 1972 Buick proportioning valve, steel lines by mee<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Steering: 1979 <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-comffice:smarttags" /><st1:City><st1lace>Toyota</st1lace></st1:City> 4x4 PS box, GM Saginaw pump, custom made hoses by me, intermediate steering shaft , “U” joints, drag link, and pitman arm by me<o></o>
Front wheel make, size: 15” Cragar SS Mags
Front tire make, size: ugh--bias plies
Rear wheel make, size: 15” Cragar SS Mags
Rear tire make, size: ugh--bias plies
Fuel tank: 1985 Chevy Blazer, 31 gallon w/1988 fuel sender and mounting straps, marine flush mount fuel filler neck in right rear fender<o></o>
ENGINE:
Year and make: 1972 Cadillac
Displacement: 500ci
Camshaft: stock
Compression ratio: 8.5:1
Heads: stock
Horsepower: 365 @ 4400rpm (according to factory publications)
Torque: 535ft.lbs @ 3000 (according to factory publications)
Manifold/Induction: stock—for now
Ignition: 1975 Caddy <st1:stockticker>HEI</st1:stockticker>
Headers/Mufflers: stock exhaust manifolds
Air cleaner: 1954 Caddy dual scoop housing<o></o>
Valve Covers: stock 72 covers with custom tops by me<o></o>
Oil Pan: 1980 Caddy Eldo 368ci rear sump pan and pick up tube<o></o>
Radiator: 1976 Dodge ¾ ton truck 4 core, fabricated my own radiator/front clip support<o></o>
TRANSMISSION:
Year and make: 1972 Caddy TH400
Shifter: B&M Megastar truck shifter<o></o>
Driveshaft: custom made to my specs by local shop
BODY:
Body style/Material: Stock F1, steel
Body manufacturer: Ford
Body mods: 1965 Mercury chrome fender spears added to doors, 1963 Ford XL500 emblems from a 1963 Galaxy glove box door added to hood sides, 1946 <st1lace><st1:PlaceName>Chrysler</st1:PlaceName><st1:PlaceType>Town</st1:PlaceType></st1lace> and Country tail light housings with blue dots fitted to rear fenders<o></o>
Bed: 2005 GMC bed front panel and floor on custom made sub structure, custom rear sill by me, custom tailgate by me, custom tailgate latches by me, battery access door in bed floor, tailgate straps by me<o></o>
Horns: Early 80’s Cadillac
Bodywork: yes it needs it
Paint: not yet, currently several shades of green with red primer showing through, blue front fenders, primer hood, and spots of black here and there…agh<o></o>
Wiring: EZ Wiring 21 circuit harness
INTERIOR:
Dashboard: 1965 <st1:City><st1lace>Pontiac</st1lace></st1:City> rear seat speaker grill adapted to my dash speaker opening.
Gauges: 1990 GM Van, gauges fitted into my stock housing with custom made bezels by me
Steering Wheel: 1972 Caddy<o></o>
Brake Pedal assy: Custom hanging pedal assy by me
Steering column: 1972 Caddy tilt & telescoping<o></o>
Seats: 1995 GMC Suburban 6 way power w/lumbar-headrests removed
Material/Color: leather, tan
Carpet: non-existent<o></o>
I hope everyone has a great weekend!!!! I am off to the lake for the 5th annual Mid-November Freeze Your Cajones Drink Too Much Jet Ski Run and Extravaganza
Bobby
1949 Ford F1
CHASSIS:
ENGINE:
Displacement: 500ci
Camshaft: stock
Heads: stock
TRANSMISSION:
BODY:
INTERIOR:
Bobby
1956 Ford F100 Panel
CHASSIS:
Frame manufacturer: OEM
Modifications: Class 4 trailer hitch added, tubular engine mount, custom transmission mount
Rear-end/Ratio: 1957 9” Ford, 3.7
Rear suspension: reversed eye lowering springs
Rear brakes: 1957 Ford drum
Front axle/suspension: 2" dropped beam axle reversed eye lowering springs
Front brakes: Disk brake conversion w/ SS flex lines
Master cylinder: 1993 Camaro with 8" SS dual diaphram booster
Steering: Toyota 4x4 PS box, HD tie rod, Gotta Show SS braid hoses, Saginaw PS pump
Front wheel make, size: 15” Unknown manufacturer
Rear wheel make, size: 15” Unknown manufacturer
Fuel tank: OEM
ENGINE:
Year and make: 1972 Chevrolet
Displacement: 400ci
Camshaft: stock
Compression ratio: stock
Heads: stock
Manifold/Induction: stock manifold with Edelbrock Carb
Ignition: stock <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com[img] /><st1:stockticker><FONT color=black><FONT face=Verdana>HEI</FONT></FONT></st1:stockticker><FONT color=black><FONT face=Verdana></P><P style=[/img]Headers/Mufflers: custom headers, mismatched exhaust/mufflers
Air cleaner: Edelbrock</FONT></FONT>
Valve Covers: Polished aluminum with ball milled flame pattern
Radiator: Walker brass, 16" electric fan, AC condensor
Serpentine belt system for polished AC compressor, Chrome alternator.
Firewall filled and smoothed
TRANSMISSION:
Year and make: 1993 T56 6 speed
Shifter: Steed Tri-ax Short throw shifter kit with Hurst lever and Momo ****, custom made leather and metal boot
BODY:
Body style/Material: Custom Cab Panel all steel
Body mods: So far: repro 99 Caddy LED taillights frenched into rear body, power radio antenna frenched into cowl, pass cowl louvers filled, LED backup lights frenched into rear pan.
Paint: not yet, will be graphic 2 tone purple and silver
INTERIOR:
Dashboard: OEM with ashtray and glove box door filled, custom brushed SS face, custom lower extension with all controls and AC vents moved from dash to extension, 2 12v outlets, emergency brake release lever. Custom SS trimmed center console containing 2 more 12v outlets, modified Miata AC/ heat controls, Alpine Head unit, CD caddy drawers, custom switch panel, inset rubber double cup holder Gauges: Dolphin electronic analog in satin black aluminum panel. Reversed windshield defrost boot, Jeep foot operated E brake pedal. Old-Air Heat/AC unit
Steering column: Ididit steel tilt column
Steering Wheel: Grant 15" banjo
Brake/clutch Pedal assy: modified 93 Camaro.
gas pedal modified 93 Camaro hanging with Lokar throttle cable
Seats: unknown manufacturer van conversion captain's chairs with fold up arm rests, driver's side 6 way power on custom mounts
Material/Color: velour grey with maroon tweed, solid grey trim
Carpet: grey level loop to be replaced
Other interior mods: Electric windows, remote door locks, security system, cruise control, auto on headlights, Miata inside door handles, 6 component speakers (4 6.5 mids, titanium dome tweeters), 2 subs with amp. Fully insulated. Interior will be fully upholstered with SS trim.
CHASSIS:
Fuel tank: OEM
ENGINE:
Displacement: 400ci
Camshaft: stock
Heads: stock
TRANSMISSION:
BODY:
INTERIOR:
1956 Ford F100
CHASSIS:
Frame: 56 Ford
Modifications: Custom tranny x-member, custom tubular motor mounts, Frame boxed to front cab mounts, Class 3 hidden trailer hitch, custom oil and tranny coolers under cab, electric fuel pump.
Rear End/Ratio: 1958 Ford truck 9-inch with Currie Tru-Trac Posi, 3.50:1, 31 spline axles.
Rear Suspension: Monoleaf springs with 2" drop shackles, traction bars.
Rear Brakes: Ford drum, 11", manual adjust.
Front Suspension: Fat Man Mustang II IFS.
Front Brakes: 10" Monte Carlo disk, stock master cylinder location. (Power brakes to come).
Steering: Manual Mustang R/P, (Power to come).
Front Wheels: 15 X 6 Speedway Alloys Rims with P235/60R15 tires.
Rear Wheels: 15 x 8.5 Speedway Alloys Rims with P295/50R15 tires.
Fuel Tank: 1978 Bronco 24-gallon tank mounted behind rear end.
Exhaust: Dual 2-1/4" dia steel tube with Dynomax Turbo mufflers, side dumps.
ENGINE:
Year and Make: 1973 Ford
Displacement: 351C V8, balanced, blueprinted.
Camshaft: Comp Cam 268H, with lifter and spring kit.
Compression Ratio: 9:1
Heads: 2 barrel 351C, Ported, polished combustion chambers, cc'd.
Intake: Edelbrock Performer, match ported.
Exhaust: Tube headers (unknown make), match ported.
Horsepower: 375 (est)
Torque: 485 ft-lbs (est)
Ignition: Mallory magnetic Pulse Dizzy.
Air Cleaner: 14" X 3" high Chrome
Valve Covers: Chrome (Summit Racing)
Oil Pan: Stock rear sump, Modified to clear IFS
Radiator: Stock 1956 Ford 6-cylinder ( 2-row) with 16" electric fan.
TRANSMISSION: 1973 Ford FMX with shift kit.
Shifter: B&M Trigger Shifter.
Driveshaft: Custom made.
BODY: Body Style/Material: 1956 Ford F100
Body Mods: Shaved hood, shaved door handles, shaved drip rail, filled cowl vent, filled louver panel, filled exterior seams, Filled gas filler, filled and smoothed gravel pan (fiberglass), (no front bumper), rear bumper narrowed and tucked. Custom Running Boards with exhaust cutouts and custom rear fender interface.
Bed Mods: Added second outer walls to widen and smooth, smoothed tail gate, filled post sockets, custom solenoid-operated latches and cable gate restraints, added filler panels behind bumper. Custom tail light brackets. Bed liner over plywood floor. Custom tonneau with interior light.
Wiring: Non-stock rats nest left by PO, with 21 fuse block.
INTERIOR: (current area in work) 1990 Cadillac Eldorado 6-way bucket seats, custom console, carpet and headliner. All dash and interior seams filled, cutom dash face plate with (8) recessed gages, lower dash extension for AC vents and controls, GPS integrated into stock ash tray, glove box shortened for AC install, power door windows (vent windows retained). Sound system = TBD.
It is a lot harder to do a "Build List" when I'm still building it.....but this is close.
CHASSIS:
Frame: 56 Ford
ENGINE:
53 f 100 : its all 53 ford save for : a gm 1 wire alternator , 83 ford truck rims and a fenton floor shifter , and headers of some brand with glass packs . 55 f 350 / 100 : geez i dont know if i have enough room but .... 55 1/2 ton frame with monte carlo front clip 80 or so , rear diff unknown all i know is its got a gm bolt pattern but looks like the dana / spicer 44 thats supposed to be there . gm column, 74 360 fe and c-6 auto , 56 f - 600 front frame rails for radiator / front sheet metal supports { not welded in yet } ,cut down 8 foot express bed of unknown for sure year , mix 'n' match gm 14 inch rims ,seatfrom 56 f-600 , front bumper 56 f-600 , oh and yeah tons of parts from other effies layin' around and its nowhere near together .
Nice Bobby.. ..I wonder if the powers can make a template that can be used as part of the gallery function so we could refer to the specs on the fly as opposed to finding a long lost or forgotten thred. This is as important as the text feature in gallery that most guys don't utilize ( see Randy Jack's as example of the usefulness) but could serve as a "how to" in some cases. Just a thought........
Again, nice !!!!
Jon
Again, nice !!!!
Jon
I've added this thread to my favorites list. I can see this as a quick reference guide when members are asking questions and the like, and we can find who's already "got this/done that", for those newer folk that ask, "Does this fit? or How do I modify that?", etc...
As for mine, I'm in the same boat as Rusty.
Donald Walker1955 Ford F100
CHASSIS:
Frame: 55 Ford
Modifications:
Rear End/Ratio: 1966 Ford Fairlane 8-inch with 3.55 ratio
Rear Suspension: 5 leaf springs with 2" drop shackles,
Front Suspension: 1987 Ford Crown Victoria front Suspension clip
Front Brakes: Factory FOMOCO passenger (NON-police model) disc brakes and rotors. Power Brake Master cylinder in stock location with remote reservoir behind seat.
Steering: FOMOCO front steer power Gearbox
Front Wheels: 15 X 7 Wheel Vintiques 14 series Gennie wheels with P215/65R15 BFG TA tires.
Rear Wheels: 15 x 7 Wheel Vintiques 14 series Gennie wheels with P235/70R15 BFG TA tires.
Fuel Tank: 1980 Chevy Van 21 Gallon mounted behind rear end.
Exhaust: Dual 2-1/4" dia steel tube rear dump.
ENGINE:
Year and Make: 1988 Ford
Displacement: 302/5.O V8,
Camshaft: Factory
Heads: Factory
Intake: Factory
Exhaust: Stock Factory manifoldsHorsepower: 375 (est)
Ignition: Ford Duraspark
Air Cleaner: 4" conical K&N Filter
Valve Covers: Factory Ford Gray cover
Oil Pan: Stock sump,
Radiator: Stock style 1955 Ford 8 cylinder Walker brand radiator with Transmission cooler
TRANSMISSION: 1988 Ford AOD
Shifter: Column Shift.
BODY: Body Style/Material: 1955 Ford F100
Wiring: Pure Motorsports fuseblock used to create wiring harness
INTERIOR: Factory seat covered in cloth and Vinyl along with the installation of a center armrest. Sanyo Single Din Cassette/CD Player with 4 Pioneer speakers. 1983 Ford Van column modified for no key.
CHASSIS:
Frame: 55 Ford
Modifications:
ENGINE:
Camshaft: Factory
Heads: Factory
Intake: Factory
on
1 Post
1948 Ford F1
CHASSIS:
Frame manufacturer: 1972 CHEVY,
Modifications: Z cut shortened, epoxy painted, C-notched for rear diff.
Rear-end/Ratio: 1972 12 bolt CHEVY, Haven't cracked it open yet??
Rear suspension: Lowering kit diff over spring pack.
Rear brakes: 1972 CHEVY drum will be switching to disc.
Front suspension: stock all bushings, tie rods, etc replaced new.
Front brakes: Stock disc, all bearings replaced.
Master cylinder: 1980 CHEVY with proportioning valve to follow.<O</O
Steering: Stock 1972 CHEVY
Fuel tank: None yet planning for 20gal Blazer tank with, marine flush mount fuel filler neck in the bed.<O</O
ENGINE:
Year and make: 1984 GM
Displacement: 305 to be replaced with 1962-67 327 SBC
Camshaft: lumpy
Compression ratio: ?
Heads: stock
Horsepower: between 275 and 350 hp (according to factory publications)
Torque: ?
Manifold/Induction: Edelbrock aluminum
Ignition: Stock to be replaced with MSD Ignition/distributor
Headers/Mufflers: SBC Shortys planned
Air cleaner: ?<O</O
Valve Covers: Either Chevrolet script or Corvette<O</O
Oil Pan: Stock<O</O
Radiator: Undecided - Thinking about reworking the stock rad.
TRANSMISSION:
Year and make: 1972 CHEVY TH400
Shifter: Lokar Shifter<O</O
Drive shaft: Shortened and balanced by machine shop.
BODY:
Body mods:
- Front fenders widened 4"
- Molded flares around wheel opening (in steel)
- Custom cab mounts to fit CHEVY Frame
- Running boards stretched and modded to fit body drop.
- Floor panels in cab cut out and replaced
- Planning on using cowl vent as ram air for engine
Bed: 1953 Ford bed will be dropping front and rear skirts. Custom made sub structure for floor installed, Stock rear sill, Stock Script tailgate, Rear fenders welded to bed, rear roll pan with license plate recess.<O</O
Horns: AAAUUUUGGGAAAHHHH!!!!!
Bodywork: in progress
Paint: Early summer 2008(with any luck)
Wiring: EZ Wiring 21 circuit harness (on order)
INTERIOR:
Dashboard: Looking at graft options for gauge cluster<ST1</ST1.
Gauges: Depends on final gauge cluster design
Steering Wheel: Stock 1972 CHEVY to be replaced with Grant wheel.
Insulation: Dyna mat insulation/sound barrier on order.<O</O
Brake Pedal assy: Stock 1984 GM
Steering column: 1972 CHEVY Column shifter removed.<O</O
Seats: On the hunt.
Material/Color: ?
Carpet: non-existent<O></O>
WILL BE UPDATED AS PROJECT PROGRESSES......
CHASSIS:
ENGINE:
Camshaft: lumpy
Heads: stock
Torque: ?
Air cleaner: ?<O</O
Oil Pan: Stock<O</O
TRANSMISSION:
BODY:
Body mods:
INTERIOR:
Seats: On the hunt.
Material/Color: ?
on
1 Post
Hey guys, here we go
CHASSIS: 56 Ford frame
76 Nova subframe
Rear Suspension: 1995 S-10 Blazer leaf springs, with custom mounts and hangars
65 Ford F100 9" rear end with 3:25 gears
Driveshaft: Custom
Master Cyl: 1985 S-10 Booster and master cyl
Rear brakes stock for 65 F100
Front Brakes : factory disc
Steering: 1987 Trans-Am quick ratio steering box
Front wheels: 15x7 Early Wheel Co. Smoothies
Rear Wheels: 15x10 Early Wheel Co.Smothies
Fuel Tank: Jaz Fuel cell 25 gal
Exhaust 2-1/4" dia. aluminized pipe with dual chambered glass packs
ENGINE
1988 Chevy 305 (ashamed, and crying)
Camshaft: Crane 252 RV
Heads:1985 model PITIFUL AND LOW COMPRESSION
Exhaust: Stock cast iron manifolds
Horsepower: Not much! probably around 130
Ignition: Accell HEI
Air Cleaner: Ford Motorsport 13"
Valve covers:Aftermarket composite, with repro Y-block decals
Oil Pan:Stock
Radiator: Stock Recored
Transmission: 350 Turbo with shift kit
Shifter: Column Shift on 1979 Cadilac tilt telescopic steering column
Body: STEEL and bondo
Modifications: filled roof seam, filled door jambs (spot welds), flip hood, extended running boards, raised bed fenders (72 model bed), no tailgate chains, custom bed cover,'93 Geo Metro dash cluster, centered license plate, LOWERED a bunch
Interior: Factory seat with custom made back rest with drop down armrest from rear seat of 1990 Cadilac, covered in Alante Vinyl and Emperor cloth.
Vintage Air, JVC CD player, bowed headliner, '78 Trans-Am Steering wheel custom covered, custom door panels and column shroud
Upholstery done by Clark's Upholstery (Me)
Paint: 1993 Ford Fiesta Aqua, and White (fleet color) PPG Acrylic Enamel (real paint)
76 Nova subframe
Driveshaft: Custom
ENGINE
Oil Pan:Stock
on
1951 Mercury M-3
(Current and future modifications)
CHASSIS:
Frame manufacturer: 1978 F250
Modifications: Shortened and narrowed
Rear-end/Ratio: 1969 Dana 70B 3.73:11
Rear suspension: lowered
Rear brakes: 12x3" drums
Front suspension: Twin-I-beam
Front brakes: F-350 DRW hubs with 12 9/16" rotors and dual piston calipers
Master cylinder: Later Ford dual disc 1" bore
Steering: 73 Ranchero steering box with 80's F-150 steering linkage
Front wheel make, size: 16x6"
Front tire make, size: 235/85/R16
Rear wheel make, size: 16x6"
Rear tire make, size: 235/85/R16
Fuel tank: 1993 F-350 18 gallon poly tank
ENGINE:
Year and make: E7TE 302 block
Displacement: 331
Camshaft: Comp Cams 35-304-8
Compression ratio: 9.0:1
Heads: 351W D0OE
Horsepower: 275 @ 4500rpm
Torque: 362 ft.lbs @ 3500
Manifold/Induction: 1996 Explorer 5.0L
Ignition: Ford TFI
Headers/Mufflers: Sanderson FF2
Air cleaner: Custom cold air intake
Valve Covers: stock 86-93 Mustang GT
Oil Pan: Chrome dual sump
Radiator: Custom built with stock mounting brackets
TRANSMISSION:
Year and make: 1992 AOD
Shifter: Lokar 19" floor shift
Driveshaft: Shortened F-150 shaft
BODY:
Body style/Material: Stock M-3, steel
Body manufacturer: Ford Canada
Body mods: 1951 M-6 front fenders
Bed: Modified 1953 F-350, shortened and tubbed. Widened fenders
Horns: Stock dual trumpet
Bodywork: by me
Paint: White with black fenders
Wiring: Custom by me
INTERIOR:
Dashboard: Stock
Gauges: 5" TPI
Steering Wheel: 1969 F-350 with trim ring
Brake Pedal assy: Modified stock pedals
Steering column: 1969 F-350
Seats: stock
Material/Color: Vinyl and tweed
Carpet: rubber floor mat
CHASSIS:
ENGINE:
Displacement: 331
Heads: 351W D0OE
Ignition: Ford TFI
TRANSMISSION:
BODY:
Bodywork: by me
INTERIOR:
Dashboard: Stock
Gauges: 5" TPI
Seats: stock
CHASSIS:
Frame: 56 Ford F-250, 118 inch wheelbase long bed
Modifications: Dual master cylinder/power brakes from Master Power, SS brake lines all around
Rear End/Ratio : Dana-60/4.88
Rear Suspension : Stock
Rear Brakes : Stock drum
Front Suspension : Stock straight axle
Front Brakes : Stock drum
Steering : Stock, very sloppy
Front Wheels : Stock 16.5 inch
Rear Wheels : Stock 16.5 inch
Fuel Tank : Stock, "air freshener" for the cab
Exhaust : Missing from the cab back, very loud
ENGINE :
Year and Make : 1957 Ford
Displacement : 292 Y-block
Camshaft : Factory
Heads : Factory
Intake : Factory, -9425A. Have a -9425B waiting to go on.
Exhaust : Stock Factory manifold with the crossover tube, but have Ram Horns waiting to be installed once they get coated.
Horsepower : unknown
Ignition : Stock
Air Cleaner : 1961 Cadillac. Looks ridiculous and out of place, but it fits for now until I can replace the old WCFB carb with something more standard
Valve Covers : Stock
Oil Pan : Stock
Radiator : Stock
TRANSMISSION : 3 speed manual
Shifter : Column Shift
Driveshaft : Stock
BODY : Stock
Wiring : Rat's nest.
INTERIOR : Original bench, recovered in vinyl in the 80's, now cracked.
ENGINE :
Camshaft : Factory
Heads : Factory
Ignition : Stock
Oil Pan : Stock
Radiator : Stock
Driveshaft : Stock
BODY : Stock
