key less entry question
Old Sep 24, 2010 | 12:36 PM
bigbubba87's Avatar
bigbubba87
I was wondering is there a way to make my key less entry work with my truck running? If the ignition is on my key less remote will not lock or unlock the doors. I would like to be able to leave my truck running and have my key less remote and be able to lock and unlock the doors is there a way to do this or not?
Old Sep 24, 2010 | 03:27 PM
koabob's Avatar
koabob
check out tubo-life saver you can set the timer to let engine cool down and it will shut down. you can get it to work with the key-less entry.
Old Sep 24, 2010 | 07:13 PM
st8yd's Avatar
st8yd
Lock the doors with the switch as normal, when the drivers door unlocks, lock it manually and it will stay.
Old Sep 24, 2010 | 07:49 PM
eggturner's Avatar
eggturner
if you hit 7/8 9/0 at the same time it will lock the doors when the truck is running, I do it all the time in the winter if it's at a short stop and it keeps the truck warm. Then reopen like you normally would with the code.
Old Sep 24, 2010 | 07:59 PM
bluescrew's Avatar
bluescrew
i think hes talkin' about using his FOB... when my truck is running the FOB doesnt work
Old Sep 24, 2010 | 11:08 PM
bigbubba87's Avatar
bigbubba87
my truck does not have the numbers it just has the little button for your key ring and if it will not work then that awnsers my question Thanks
Old Sep 24, 2010 | 11:14 PM
firedewd's Avatar
firedewd
That happened to my wife when I was out of town. She started the truck and went back inside and some how hit the door lock as she got out. Spare keyfob would not open the door. Had to let it run for 45 minutes until parts shop freind of ours could stop by and pop the lock.
Old Sep 25, 2010 | 11:25 AM
itsjustdan26's Avatar
itsjustdan26
Do all of our trucks come with a fob? If so the P/O lost it... Is there anywhere in the truck to look to see if there is a wireless reciever?
Old Sep 25, 2010 | 11:54 AM
Pocket's Avatar
Pocket
The key fob is an option, mainly it depends on the trim level of the truck. It was standard for the Lariats, and I think most XLT's had it. I'm sure it's rare to find an XL with one.
You could have the Ford dealership pull up your vin and tell you if it came with the keyless entry option.
Old Sep 25, 2010 | 11:06 PM
itsjustdan26
Thank you for the reply Curtis, Ill call Ford on Monday to see what I can find.
davidkstyler
Feb 3, 2023 11:48 AM
jbtruck02
1997 - 2003 F150
Jun 23, 2013 06:29 PM
SDElwood
Jan 23, 2013 09:08 PM
waldreps
Dec 23, 2006 09:50 AM
bbeaumont
Dec 19, 2006 11:10 AM
