Decoding
Old Sep 27, 2010 | 02:00 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Eston Newbern
I just bought ANOTHER running rust bucket can you decifer for me I think it is a 240 cid but trans and rear ratio is unknown.
F10JL661479
The seller did the bill of sale based on he says it's a 1966 since 66 is in the tag number as above, please decifer for me.
Can you tell the rear ratio with this or do I need the tag off the rear end? Original color? thanks
The seller did not have a clue when he made out the bill of sale. It's not a 1966 ... it's a 1965.
F10 = F100 2WD
J = 240 IV I-6.
L = Michigan Truck Assembly Plant.
661479 = 1965 assembled March 1965.
661,479 is the Numerical Sequence of Assembly, the trucks specific serial number.
1965 serial number range: 580,001 thru 732,000.
March 1965 serial number range: 660,000 thru 671,999.
The Warranty Plate, located on the left door face below the latch, has codes for the COLOR, AXLE, TRANS and etc.
Old Oct 3, 2010 | 10:20 AM
Eston Newbern's Avatar
Eston Newbern
Another Question concerning my OTHER 65 (have 3 )
The following is another 65 I bought BUT the owner billed it as a 64
1st Question, was there ANY late 64s that had the I Bean front suspension?, this one does
Here is the Warranty Number as it is on the door 64? 65?
F 1 0 0 D K 7 1 5 0 7 5
W.B. 115
COLOR M = ?
MODEL F101
BODY 581 = ?
TRANS A = ?
AXLE 07 = ? 3.00
MAX G.V.W. = 4200
CERT 172 = ?
H.P. 4000 = ?
RPM 21 = ?
I think I've got some of the above out of order, since the way the tag is made I'm not sure, BUT every decoder I can find doesn't show the above as a valid number, what do you have?
Thanks
I hope I haven't bought a bogus stolen truck Yikes, that's why I haven't tried to get this corrected at the tax office after I found the problem, now the guy I purchased it from is no longer found.
Old Oct 3, 2010 | 10:30 AM
Grandpa's64's Avatar
Grandpa's64
Hopefully NumberDummy can help me out also. This was my Grandfather's 1964 F-250. I'm new to this forum and also Fords and want to take this pickup back to original. Here is the info.
F25BG480521
128 B F250 L81 F 26
7500 132 3600 55
From reading other forums I have found out a little with the vin and color code but unsure about everything else. Thanks for the help.
TA455HO
40
Jul 19, 2015 10:11 AM
IntrstlarOvrdrve
Dec 11, 2014 05:12 PM
pupcar
May 15, 2014 10:18 PM
HillBillyBuddha
May 14, 2013 07:56 PM
Shorty 66
Mar 23, 2009 01:21 AM
