I just got this truck. It's kinda weird with some of the options. The warranty plate was painted so I think that the trans and axle codes are correct. Thanks
vin- f10yk834573 / wb-129 / model-f100 / body-481 / trans-a / axle-08 / gvw-5000 / hp-172@4000 / dso-511387
F10 = F100 2WD
Y = 352 2V
K = Kansas City Assembly Plant
834573 = Assembled March 1966
129" Wheelbase
No COLOR code
F100 2WD, 5,000 lbs. GVWR
481: 4 = Medium Beige Crush Vinyl & Medium Beige Wicker Pattern Vinyl // 81 = 81A Standard Cab
A - Ford type 3.03 3 Speed Manual all Syncromesh Transmission
08 = Ford 9" Rear Axle / 3.50-1 / non Limited Slip / 3300 lb. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating
172 NET HP @ 4,000 RPM.
DSO: 511387:
51 = Denver CO Ford District Sales Zone Office, where the original selling dealer ordered the truck from.
1387 = Domestic Special Order Number. The truck was ordered special from Ford, not "bought off the lot."
Since there is no COLOR code, the special order prolly had to do with the truck being painted a non standard Ford color.
in 65 and 6 it was optional...in 66 on I believe F350s there was a dash pad delete option...I believe its mentioned in my gallery under package composition..
