Decoding
Old Sep 23, 2010 | 03:50 PM
DISCOUNTDAVE's Avatar
DISCOUNTDAVE
Decoding
Just purchased a '66 F250 yesterday. While trying to research the rear-end, I found a discrepancy in the VIN on the warranty plate.
F25YK733093
The plate is on the rear face of the driver door, consistent with the '66 model, yet the Y represents a '67 model 352 motor. From what I've read, the '67 warranty plate is under the hood though.
Any clarification would be great.
Old Sep 24, 2010 | 06:37 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F25YK733093
The plate is on the rear face of the driver door, consistent with the '66 model, yet the Y represents a 1966 & '67 model 352 motor.
From what I've read (where?) the '67 warranty plate is under the hood though.
Welcome to FTE
I don't know where you read that hocus-pocus...it's in-correct.
F25 = F250 2WD.
Y = 352 2V.
K = Kansas City MO Assembly Plant.
733093 = 1966, assembled August 1965.
VIN engine code D was used in 1965 for the 352 2V / Y = 1966/67 352 2V / Y = 1968/76 F100/350 360 2V.
1963/80 F100/350: The Warranty Plate is located on the left door face below the latch...except on Open Drive-Away's.
The Warranty Plate is located on the firewall of Open Drive-Away's, because these trucks (Cowl & Windshield & Chassis & Windshield) do not have a cab of any kind.
On some of these trucks, you may find a "Buck Tag" on the firewall...which was used by assembly line workers only.
The rear axle is a Dana 60. Its AXLE code is listed on the Warranty Plate, and if you post all the codes from the plate, I can decode all of it.
Old Sep 25, 2010 | 09:52 PM
G Sutton's Avatar
G Sutton
I just removed my Buck plate from the firewall last nite to restore it and fount it was a warranty plate the assembly line workers turned around and used the blank side to stencile the paint code on. Thanks for the new phrase- buck plate 66 250 8ft bed
Old Sep 26, 2010 | 11:10 AM
DISCOUNTDAVE
VIN - REF. ABOVE
W.B. - 129
COLOR - W
MODEL - F250
BODY - B81
TRANS. - A
AXLE - 24
MAX. GVW LBS - 07500
CERT. NET. H.P. - 172
R.P.M. - 4000
DSO - 51
Old Sep 26, 2010 | 11:49 AM
masterqi's Avatar
masterqi
DSO - 51
Hey that's great you live in Colorado and got a locally sourced truck!
Old Sep 26, 2010 | 12:21 PM
NumberDummy
VIN - REF. ABOVE
W.B. - 129
COLOR - W
MODEL - F250
BODY - B81
TRANS. - A
AXLE - 24
R.P.M. - 4000
DSO - 51
129" Wheelbase.
W = Marlin Blue.
F250 2WD, 7500 lbs. GVWR
B81: B = Medium Blue Crush Vinyl & Medium Blue Cody Pattern Woven Plastic // 81 = 81B Custom Cab.
A = New Process 435 4 Speed Manual Transmission.
24 = Dana 60 Rear Axle / 4.10-1 / non Limited Slip / 5200 lb. Rear Axle Capacity.
7500 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4000 RPM
51 = Denver CO Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Sep 26, 2010 | 01:06 PM
DISCOUNTDAVE
Yeah, I thought that was cool also. There have been only 2 previous owners. The couple I bought it from, bought it from another local family that we know back in '87. They are well into their 70's now. He just used it to pull around their camper trailer, haul trash off, and pick up firewood. He only put on about 30,000 miles. The original owner sold it to him when he sold his ranch after his son died and his daughters didn't want to continue the ranching business.
Now, it has come to rest in my garage. I will not make a hot-rod, or low-rider out of it. When it comes time for an overhaul, I might beef up the motor a bit...but that's it. It's got 121,000 miles on it.
One thing that is tormenting me is this...I really like the "Miss Daisy" color scheme and would like to do it to mine, but I also think I should just keep it like it originally came. Obviously, I will re-paint it, but can't decide which direction to go with it.
Thank You Numberdummy for providing all the specs on it. I REALLY wanted to know the name of the paint.
Old Sep 26, 2010 | 01:25 PM
DISCOUNTDAVE
Oh, also, I was heading into town to take the kids to soccer. While I was there I was gonna pick up a bulb for the tail light. The tail light function works, but not the blinker or brake light function. The front blinker works though, so I don't think it's the switch. Does anyone happen to know the model#? I was thinking it was 1140, but can't remember and can't remember where I found it at.
Old Sep 26, 2010 | 02:16 PM
NumberDummy
#1034 or #1157 double filament bulb. Either will work, and either is also used for the parking lights.
Parts catalog calls for 1157, but one never knows what may be available, so 1034 can be substituted.
1140? No such number is listed.
Old Sep 26, 2010 | 02:38 PM
DISCOUNTDAVE
ehh, bad memory. Thanks though.
While we are on the subject of lights, are thefront parking lights SUPPOSED to turn off when the headlights are turned on?
Old Sep 26, 2010 | 02:41 PM
NumberDummy
While we are on the subject of lights, are the front parking lights SUPPOSED to turn off when the headlights are turned on?
Exactly...that's the way things operated back then, not only on trucks but passenger cars as well.
People make the mistake of comparing these old rolling piles of misery with new piles. Should not do that.
Old Sep 26, 2010 | 03:22 PM
DISCOUNTDAVE
Mine is more of a rolling pile of joy rather than pile of misery.
Old Sep 26, 2010 | 03:40 PM
NumberDummy
You say that now...but just wait till something breaks, and you have to go hunting for the parts.
I've owned 331 vehicles since 1956. Excepting the 15 or so I bought new, the others were old rolling piles of misery, some of which I sank a ton of money into.
Old Sep 26, 2010 | 05:18 PM
Eston Newbern's Avatar
Eston Newbern
Number Dummy need this decoded too
Thanks for your help on the Disc Brake issue, I just bought ANOTHER running rust bucket can you decifer for me I think it is a 240 cid but trans and rear ratio is unknown.
Is there a engine marking or something that sticks out that's different than the other 6 cids?
F10JL661479
The seller did the bill of sale based on he says it's a 1966 since 66 is in the tag number as above, please decifer for me, can you tell the rear ratio with this or do I need the tag off the rear end? Original color? thanks
Old Sep 26, 2010 | 05:28 PM
masterqi's Avatar
masterqi
Originally Posted by Eston Newbern
F10JL661479
Uhhh, no. Never heard that one before! That is part of the sequential build number and just happens to have a "66" in it. Could have been an "87"...doesn't mean it came off the line in 1987! P.S. Your truck is a 1965 and specifically, 661479 is March 1965.
