Connecticut Chapter Join Chapter, Leader:
300 build thread
Old Sep 28, 2011 | 09:02 AM
  #271
Davidwent's Avatar
Davidwent
Originally Posted by ArdWrknTrk
What year is the truck?
Does the alternator have an external fan like his?
If so, it is a fire prone 2G and doesn't put out enough to run the fan(s).
Hey Jim
It is off a 78 motor,
It's at my storage unit where I am doing work but I am almost positive no fan just belt pulley
Old Sep 28, 2011 | 09:07 AM
  #272
Davidwent's Avatar
Davidwent
HEY jOSH,
i WAS LOOKING AT YOUR PICS AGAIN. aS YOU KNOW i AM VERY NEW TO THIS AND DON'T KNOW A LOT BURT LOOKING AT YOUR MUFFLER SO CLOSE TO FRAMe ISN'T THAT A POTENTIAL FUTURE RATTLE?
dAVID
***** sorry about caps I don't look up much and don't feel like retyping. not yelling at you lol
Old Sep 28, 2011 | 09:24 AM
  #273
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
1978 would be a 1G alternator with a seperate regulator mounted somewhere like inside the fender. (still an external fan)
The 2G was the first internally regulated version, external fan...
3G eliminated the fire prone charging plug of the 2G, added a second fan (both internal) and upped the amperage to 95, or 130 for vehicles equipped with electric fans.
The 130A ( large case) version came in three mounting configurations.
Side mount for later models, 7" pivot, and 8.25" pivot for various applications.
I think the 3.0 v6 got the 7" and the 3.8 v6 got the 8.25.
Originally Posted by Davidwent
Hey Jim
Old Sep 28, 2011 | 09:33 AM
  #274
Davidwent's Avatar
Davidwent
The 130A version came in three mounting configurations.
Awesome info Jim Thank you.
I did read an article somewhere maybe that gofastforcheap web site about getting a 100A off some car I don't remember which now, do you have any idea?
TIA
David
Old Sep 28, 2011 | 09:36 AM
  #275
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I don't recall any 100A alternator off a later model Ford that swaps right in like a 3G does.
The 3G's were commonly pulled from Taurus/Sable V6's.
Old Sep 28, 2011 | 09:40 AM
  #276
Davidwent's Avatar
Davidwent
Yup now that you mentioned he did say a Tauras and also mentioned 3 grooves instead of four to help identify
Thank you sir!!
David
Old Sep 28, 2011 | 09:43 AM
  #277
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Actually you are looking for Two holes (148mm diameter case), instead of Four (135mm) between the three pairs of ribs on the front.
4 holes= 95A, 2 holes=130A
I'll find a pic...
Old Sep 28, 2011 | 09:48 AM
  #278
Davidwent's Avatar
Davidwent
Actually you are looking for Two holes, instead of Four between the three pairs of ribs on the front.
I'll find a pic...
Awesome TY!
Old Sep 28, 2011 | 09:50 AM
  #279
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I edited my post above, hope it helps...
Sorry for the hijack Josiah.
Old Sep 28, 2011 | 10:01 AM
  #280
Davidwent's Avatar
Davidwent
Very cool Thanks alot JIM!!
Just printed the pics
I really hate how ignorant I about motors, but I am learning tons from you guys
Thanks to all!!
David
Old Sep 28, 2011 | 02:35 PM
  #281
Zookie400's Avatar
Zookie400
david- the muffler is tucked pretty well but the only time it can rattle is if something comes loose or an exhaust mount rips apart, there is probably 4" minimum clearance in the tightest spots. there isnt much wobble with the efi manifolds and walker y-pipe, it has a good hold on the front side and would probably hold everything solid all the way back even if he did lose a rubber mount.
Old Sep 28, 2011 | 03:47 PM
  #282
Davidwent's Avatar
Davidwent
Thanks for the info Aaron. Good to know as I am also planning to use efi manifold and walker y pipe
Thaanks!
David
Old Sep 28, 2011 | 03:49 PM
  #283
Davidwent's Avatar
Davidwent
Just a thought today.... Has anybody used the efi manifolds and just run dual exhausts back. I am assuming it would take some custom exhaust work, but the "cool factor" might make it worth it
TIA
David
Old Sep 28, 2011 | 03:51 PM
  #284
Zookie400's Avatar
Zookie400
josiah would remember better than i, but i think its a 1 7/8" hole saw you will need to open up the hole in the pipe, right at the Y.
Old Sep 28, 2011 | 03:53 PM
  #285
rocdril's Avatar
rocdril
Im pretty sure it was 1 15/16"
