Offroad & 4x4
Know what I hate?
Old Nov 26, 2010 | 05:32 PM
  #166
Prozon's Avatar
Prozon
What is your definition of a pothole?? Hahaha.
Old Nov 26, 2010 | 05:44 PM
  #167
tjc transport's Avatar
tjc transport
i ain't rite
there is a section of the road that the right lane is partially collapsed. and there is around a 6 inch dip on one side.
whenever i have to use that road, i always use the left lane, but this morning, there was a string of tractor trailers in the left lane, and i could not get over. so i had to continue over the bad stretch.
the front springs were pretty bad, and i was going to replace them in the spring anyway.
it just stinks that i don't have the money readily available to do them now. i have to put things on hold, or sell one of the trucks to get the money to fix this now.
the worst thing about it is the 78 has no engine in it, the 79 has a spun main bearing and i have the oil pan off it, the 2000 the gas pump died, and the 88 has a broken rear main leaf, and that makes it real dangerous to drive, so i now have no running trucks. .
Old Nov 26, 2010 | 07:12 PM
  #168
Prozon's Avatar
Prozon
That sucks. Junkyard leaf pack?
Old Nov 26, 2010 | 09:11 PM
  #169
captain p4's Avatar
captain p4
I hate when my brakes are going bad in my stupid duty and I have to downshift to stop without hearing the most hellish noises... and the last time I downshift I get massive wheel hop and axle wrap - enough to pull the splines apart in the driveshaft. I had to drive about 30 miles in fwd with the rear driveshaft flopping around held up with a ratchet strap at 10mph. I had a fun night.
Old Nov 26, 2010 | 10:16 PM
  #170
fatdan460's Avatar
fatdan460
compression braking ftmfw!!!! who needs brakes anyways
potholes are evil man. about a month back my dad's dodge busted a rear leaf shackle after hitting one. no bueno.
Old Nov 27, 2010 | 06:39 AM
  #171
tjc transport
i ain't rite
nope. stock springs on both trucks.
the 02 carries a 980 lb meyers C-8.5 plow in the winter, so that pretty much wasted the fronts on that one, and the 88 has seen 22 years of abuse, including many 4 ton loads in the bed. the funny thing with the 88 is, it was a 300 six cylinder leaning against the passenger side of the bed while i was delivering it that broke the passenger side main leaf.
Old Nov 27, 2010 | 07:50 AM
  #172
hav24wheel's Avatar
hav24wheel
I think he was asking "Can you get junkyard leafs to fix it"
Old Nov 27, 2010 | 01:09 PM
  #173
Prozon's Avatar
Prozon
That was what I was asking Dave. Can't you find some ones in a junkyard to replace it cheap enough?
Old Nov 27, 2010 | 02:44 PM
  #174
tjc transport
i ain't rite
oh. ok. yea, i found a set of X code 6000 lb springs at a local yard. came off a burn truck, claim is they only have 35k miles on them. $100 each. new is around $180 each from the spring place, and $375 each from ford.
Old Dec 1, 2010 | 06:45 PM
  #175
alpha/omega's Avatar
alpha/omega
Hey Captain Dip*****! Why didnt you take the d-shaft out?
Old Dec 2, 2010 | 05:46 AM
  #176
kjett's Avatar
kjett
Or better yet, why didn't you save some of your Opana money and just buy new brakes when you knew they were worn out.
Old Dec 2, 2010 | 05:56 AM
  #177
77mud's Avatar
77mud
I thank that explains it....
Old Dec 2, 2010 | 07:30 AM
  #178
captain p4's Avatar
captain p4
Of all the toools I carry, a 12 pt 12mm socket and breaker bar wasn't included. I would've broke the ratcheting wrench I had if I put enough force on it to break the shaft loose.
Old Dec 2, 2010 | 07:00 PM
  #179
fatdan460's Avatar
fatdan460
a ratchet wrench is like what, $8 at most for that size. how much is a driveshaft or yoke?
Old Dec 2, 2010 | 07:08 PM
  #180
tjc transport
i ain't rite
for a stupid duty, a driveshaft is $675. i had to replace one this time last year for my neighbor on his "new" used truck, because a previous "mechanic" welder the u-joint cups to the shaft cause they were loose.
