sticky breaks
Old Oct 13, 2010 | 09:21 AM
  #31
Talyn's Avatar
Talyn
Just an FYI and reminder for you guys here.
They say when you replace a front caliper, that you are supposed to replace both sides.
If you replaced one side, and are having problems....
My thoughts on replacing calipers as well is to replace the rubber lines anytime you remove a caliper and replace it.
Old Oct 13, 2010 | 09:46 AM
  #32
oldbird1965's Avatar
oldbird1965
Originally Posted by chicagodragon
you finally got an answer,huh glenn? BTW what gears are you using to pull that road train of yours?
Ya, I swear, getting an answer to your questions around here is like pulling teeth! I thought for sure I had that in my signature, I do now! I believe if I had the 3's I would never have made it. Next spring that trailer stays at home, no more trains!!!!!!!!!!!!!
Mr. 427, I'm so happy your funny bone got tickled, best medicine there is!
Old Oct 13, 2010 | 10:10 AM
  #33
rn360908's Avatar
rn360908
I agree with you on replacing or rebuilding both calipers if your going to change one. Same reason that one changes both rotors at the same time.
But sometimes changing those rubber lines aren't that easy. With our trucks getting old the hard lines are rusty and the brake ends are so bad that you can't losen them up from the flex lines and they normally round off and your screwed. When I installed my new brake lines there wasn't a single line i was able to take off with a line wrench without stripping it and then having to us vice gripes to get them off, and my truck isn't even rusted up like some of these trucks up north. I know it would be nice to change the flex lines out every time but its sometime impossible to do.
Old Oct 13, 2010 | 10:16 AM
  #34
Talyn's Avatar
Talyn
Hey Ryan.
I live in Michigan.
I am a master of rust. =)
And fluid film keeps them nice.
spray the lines down with FF and then screw them in. That film will stay in there and keep it nice. =)
Old Oct 13, 2010 | 03:44 PM
  #35
rn360908's Avatar
rn360908
Hey Ryan.
I live in Michigan.
I will have to keep that in mind in the future.
Brian F100 1960
Aug 17, 2012 07:55 AM
Visseroth
21
Jan 14, 2012 11:38 AM
fwerring
Aug 31, 2010 03:52 PM
69crewcab
16
Mar 29, 2006 02:02 PM
D_STICK
1978 - 1996 Big Bronco
Jul 14, 2001 01:01 AM
