Drain plug torque?
Old Sep 20, 2010 | 10:16 PM
F3504ME's Avatar
F3504ME
Drain plug torque?
I have done all my oil changes and always used a new copper gasket and cinched it down good, never had a leak or any problem. I have never found a torque spec in the manuals? Is there an actual torque spec for the drain plug?
Old Sep 20, 2010 | 11:34 PM
robles4242's Avatar
robles4242
Auto tranny Fluid pan bolts are 11 ft lbs. Thats all the book lists. I searched over and over and cant find any torque specs for a drain plug.
What do you put a gasket on?
Old Sep 21, 2010 | 07:10 AM
Ponyboychris's Avatar
Ponyboychris
I have a Fumoto valve now but before I used to snug it up and walked away.
info on the Fumoto valve: Replacement O-rings for Ford Diesel Engines
Old Sep 21, 2010 | 10:41 AM
robles4242's Avatar
robles4242
I was jsut about to say id NEVER want one of those! Then i saw the clamp for locking it and now i think its kinda neat! I still prob would never get one tho. Too risky!
Old Sep 21, 2010 | 10:55 AM
Ponyboychris
I thought it was risky too but once you see the design of the Fumoto, you will get a better idea on how they work. Not risky at all and I don't use the safety ring. I off-road my truck on occasions plus drive through some deep snow at winter time. There is more risk of something puncturing the oil pan than having the plug fail. Plus, you never have to worry about cross-threading or stripping out your oil pan or pesky leaks around the crush washer. It's pretty cool.
Old Sep 21, 2010 | 12:25 PM
mikeyc0120's Avatar
mikeyc0120
Don't know the specs for the drain plug. Never really worried about it. I usually use german torque.... "goodntight"
Old Sep 21, 2010 | 12:35 PM
blue1ton's Avatar
blue1ton
I also have the Fumoto, no more oil drips. Don't hold me to this, but I think I remember reading somewhere the oil drain bolt is torqued @ 28 pounds??
Old Sep 21, 2010 | 12:51 PM
Stewart_H's Avatar
Stewart_H
What's risky about it?
Been running one on all my Ford's for years.
Stewart
MS86
May 22, 2015 02:00 PM
wantahertzdonut
Apr 7, 2014 09:01 PM
r___r
Dec 15, 2013 06:11 PM
Supraman
Nov 15, 2012 10:02 PM
Ubbzy
Modular V10 (6.8l)
Jun 2, 2010 06:51 AM
