engine temp
Old Sep 19, 2010 | 03:38 PM
cpettymore7777's Avatar
cpettymore7777
engine temp
i was told the reason why some people run without a thermostat in the engine is that it makes the engine run rich and gives them more power. in the winter they cover up the grille with cardboard or something so they can get heat. does this give more power? i would think it would kill you mpg and the cat would get too hot.
Old Sep 19, 2010 | 07:07 PM
Sbrown's Avatar
Sbrown
Don't do it, It will kill MPG's ... single digits. You will lose power because of too much fuel. The cat will also get plugged up after a short time also killing power. The computer will just be completely confused as it uses engine temp to determine Timing? and fuel.
Old Sep 19, 2010 | 08:14 PM
dmanlyr's Avatar
dmanlyr
And you will shorten you engine life from incomplete combustion as well as raw fuel washing the thin lubricating oil from the cylinder walls.
David
Old Sep 19, 2010 | 09:08 PM
Old93junk's Avatar
Old93junk
Don't do it.........you need a 192 degree thermostat for the EEC to be able to properly manage engine functions.......below that temp, your computer is on open loop, and MPG and performance will suck.
Thomas34461
Aug 28, 2010 03:43 PM
jimford1
Computer Chips & Tuners
Jun 5, 2008 08:03 AM
f-4x4
Aug 15, 2005 09:54 AM
cherry93lightnin
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Feb 15, 2005 11:44 AM
radrob
Aerostar
Nov 17, 2003 03:14 AM
