has any body out there had to work on the radio c/d player yet? my c/d player decided to eat 6 c/ds and want give them back. I mash the eject butten and get a c/d error. mash the c/d butten and get a no c/d and I know that there is 6 c/ds in there and this in a 03 f-250 4x4 crew
I removed the dash to get to mine. Not sure if they are the same since yours is an 03. I will look to see if I saved instructions for the earlier model years.
Edit:
I found this saved ......
Try this for the stuck cds in the radio. I was able to get them out, and the cd unit reset itself upon powering up. Remove the radio and put it on a workbench or the kitchen table. To get it apart, the front face needs to come off. I believe its a couple screws on each side, and the front face will come off and 1 wire plug to unplug. then looking from the front, gently slide the cd or cds out. Put the face back on, and reinstall in the truck. when powering up after plugging in the plugs , mine reset itself and now works again.
Here are a few threads for cd player removal I just found (I had been meaning to look these up for awhile):
I got it out using a metal hanger by bending it the same width as the holes on the front of the radio pushing it in past the locks and pushed outward and pulled and out it came! unpluged it put it on the work bench took the top metal cover off and you can see the c/ds. went back out plug it back up mashed the eject butten and out came one c/d kept mashing and got all of them to come out thanks for all the help
