Distributor wont fit?
Old Sep 18, 2010 | 08:22 PM
Therum's Avatar
Therum
Hello Guys,
I have been working on my 77 F100/C6 2wd Auto. I have had it for about a year but it has been sitting at my grandfathers house for the past 11months because they could not get anyone to finish work on it. I have been working on it for about a week now getting things back together. It has a 351w (i believe) in it that was put in before I had it shipped to me. It did not have a distributor and I got one out of a thunderbird that did have a 351w(Or so he said and it looked just like mine. I went to put it in and the distributor will not sit down in there. I know about the oil pump shaft and turned the crank little by little to see if it will seat but it will not sit down far enough for the gears to mesh. It will only get down as far as the bottom of the bobbin looking thing that has the o-ring attached. I can almost freely turn the rotor. It catches just enough to let you know something is actually down there. From what I understand the only thing that should be standing in my way is the oil pump drive shaft or possibly the cam gear on the distributor. I'm at a loss for the moment. Maybe the distributor is a really tight fit and I need to "Perfectly" align the shaft and bobbin (Dont know that else to call it) please see the picture for a better explanation.
Thanks guys ahead of time.
Old Sep 18, 2010 | 09:15 PM
Greg B's Avatar
Greg B
If it's the correct distributor, the oil pump drive shaft isn't letting the distributor drop in all the way. You may need to use a long straight blade screw driver to turn the oil pump shaft shaft until the distributor will drop in.
Old Sep 18, 2010 | 09:58 PM
cartmanstwin's Avatar
cartmanstwin
actually the screw driver won't work, it should be an 8MM hex head on it. so with great care, an 8MM socket on long extension. it's how I prime oil through my motors before initial start up. but, be careful, you drop the socket in, and you've gotta tear the pan out to get it back.
Old Sep 18, 2010 | 09:59 PM
cartmanstwin
But, if your lines are correct, either something is keeping the housing from going down. Or, the distributor is too long.
Old Sep 18, 2010 | 10:46 PM
79 f350ts's Avatar
79 f350ts
how sure are you about it being 351w? from your drawing it looks like your putting a 351w distributor into a 302, wich takes a shorter dist
Old Sep 19, 2010 | 07:20 AM
J Hodges's Avatar
J Hodges
the oil pump shaft for a 351w is also bigger than a 302. Before we could give you a definate answer we need to determine if you have a 302 or 351w and what your distributor came out of. A 351w should be about 12 inches across the intake from valve cover vc. A 302 should be about 9 inches from vc to vc
Old Sep 19, 2010 | 08:39 AM
Therum's Avatar
Therum
OK. I will take some pictures and measurements when I get back from church.
Thanks!
Old Sep 19, 2010 | 12:10 PM
Therum's Avatar
Therum
Well, it measures 9in so I guess its a 302 . I was told it was a 351w by the goof I bought it from. But I guess I cant complain yet since I only paid $250 for it. As long as it runs as the seller promised. So I would assume that's my problem. Back to the junk yard.
Thanks guys!
Old Sep 19, 2010 | 12:12 PM
Therum's Avatar
Therum
Doe anyone have a few pictures of their vacuum lines? This thing doesn't have a single vac line installed except for the pcv.
Old Sep 19, 2010 | 03:41 PM
Greg B's Avatar
Greg B
Thanks, cartmanstwin. I forgot. Been working on too many other brands lately.
money pit 69
Oct 16, 2015 01:35 PM
HarryPutnam
May 21, 2011 07:26 PM
OrangeJuice
Jun 5, 2009 02:21 PM
Okiedokie
Apr 19, 2008 10:18 PM
stuffman
20
Mar 10, 2004 02:39 AM
