Turn signal problem
Old Sep 19, 2010 | 06:46 PM
claydm67's Avatar
claydm67
Turn signal problem
Hey everyone. So my problem is the turn signals don't work. All other lights work, 4 ways work and when you work the turn signal up or down there is a stronge click so I 'think' the contacts are good. any idea's what it is or could be.
Thanks
Old Sep 19, 2010 | 07:12 PM
bobwires's Avatar
bobwires
the flashers get power from a different circuit than the blinkers. reason is so the flashers can work with the ignition off.
if they all went out at the same time it has to be in that circuit - fuse, wire, switch.
