DISTRIBUTOR HELP
Old Oct 14, 2015 | 01:14 PM
money pit 69's Avatar
money pit 69
DISTRIBUTOR HELP
Thank You for reading a little help needed. My 1987 F-250 4x4 with a 351w needs a rebuild. So I bought a replacement engine on craigslist. It is a 1990 as far as I know according to the seller. It had EFI to which I'm changing to carb. THe EFI was not complete and my carb off 87 is. First of all I'm still using the 87 so I don't want to tear apart until new motor is ready. MY NEW ISSUE IS AS I CONTINUE MORE ISSUES ARISE. NOW I WENT TO INSTALL MY NEW PROCOMP EFI DISTRIBUTOR AND IT WILL NOT SEAT ALL THE WAY DOWN. SITS UP ABOUT 3/8" OR SO. TURNS WHEN ENGINE ROTATED. THE ONE I BOUGHT IS FOR 351W # PC6003D-1 IS THERE A DIFFERENT OIL PUMP SHAFT NEEDED. THX DAVID
THX David
Old Oct 14, 2015 | 04:33 PM
f5fordgirl's Avatar
f5fordgirl
Did the engine you bought have a dist, is it and the new one the same length from mounting flange to bottom?
Old Oct 14, 2015 | 04:47 PM
money pit 69
Like a DUMMY I traded it with the EFI unit. So I can't answer your question.
Old Oct 14, 2015 | 05:48 PM
money pit 69
All is OK i just hadn't pushed it down hard enough. My bad. Thx for helping
Old Oct 15, 2015 | 07:49 PM
ADOR's Avatar
ADOR
One last thing to double check before firing up is what cam does your new engine have. If the new engine has a regular camshaft you will be fine, if it has a roller camshaft you need the correct gear on the distributor. If you use a regular cast gear on a steel cam you will eat the gears away.
Old Oct 15, 2015 | 08:34 PM
money pit 69
THX ADOR for the heads up .There was a warning note with the dizzy. Not being a expert by any stretch I thinking stock due to the stock rocker arms and lifters.
Old Oct 16, 2015 | 01:35 PM
ADOR's Avatar
ADOR
Stock yes, but newer 351w have a roller cam stock. When you pull the intake you will know for sure.
The_SnowMan710
20
Feb 11, 2008 06:47 PM
xlt guy
Apr 24, 2006 09:16 PM
martimani85F250
Feb 8, 2006 03:08 PM
customnotch
1978 - 1996 Big Bronco
Oct 20, 2005 05:31 PM
