Disable automatic locking on 04 Superduty - NOT the same thing as Autolock
Hi! This is my first post, but my husband lurks around here a lot to find answers for our Fords when they're acting up, so thanks for all the help you've already given me!
The issue I wanted to ask about today is regarding my 04 F-250 6.0L. I have already tried disabling the Autolock feature using the instructions in the manual (which didn't work, assuming by the lack of horn chirps I heard when I attempted it multiple times), and that's not the issue anyway. Autolock appears to be that thing it does when you start driving and it automatically locks at a certain speed or when you slow down a certain amount, etc.
The problem I need to solve is the automatic locking of the doors when the ignition is turned to ON. Literally every time I put the key in the lock and turn the key to ON (not START), the doors lock. When I turn the key to OFF, the doors unlock.
Today was basically my worst fear, because I got my son all strapped into his carseat, started the truck while I was in there, did not turn on the A/C (because hubby tells me to wait a second after starting it to turn it on), and then I closed the back door to go around and get in the front. The instant I did it, I realized I had not accounted for the automatic locking feature and I was locked out of my running vehicle while my 2-year-old was strapped in the backseat. Thankfully, I had left the windows cracked and was able to use a water hose to hit the down button and get the window open enough to get in, but if not, I would have had to break my window to save my kid.
So you can see why I hate that the doors automatically lock when the key is turned. It has nothing to do with the transmission or movement or braking or anything, it is literally connected to the ignition switch. Any ideas on how to bypass it? I don't care if the actual Autolock stays on, that's fine. The issue is the locking and unlocking based on the ignition switch.
(Also, sorry for the novel. I'm still a little shaky after locking my kid in a hot car in July in Texas, so I'm rambling a bit. It was a scary time.)
it's almost like yours is working in reverse of what it's supposed to do. I know with the keys in the ignition, if you lock the drivers door with it open and then shut it, it should unlock automatically to prevent being locked out. Dealer should be able to replace the module or whatever it is easily
Sounds like there is an aftermarket alarm or remote start on the truck my old auto page did the exact same thing. The stock vehicle security module doesn't give you the option to have the door locks do that. Look under the dash where the fuse panel is and see if there is an black box under there that is spliced into other factory wires that doesn't say ford on it.sounds like a good reason to add one of the stick on keypads to the driver door so you can get in with out the key would have been much easier than using the hose good thing you left the windows cracked today. https://www.ebay.com/itm/171401976103
Tony647
03-23-2005 03:00 AM
