5.0 HO complete engine
Old Sep 14, 2010 | 11:56 PM
Restor56's Avatar
Restor56
Hi i just want to know what kind of tranny can i use for this baby? it is out of a 1995 mustang gt,
Old Sep 14, 2010 | 11:59 PM
52 Merc's Avatar
52 Merc
Any kind of tranny you want. There are plenty of manual or automatic options available.
Old Sep 15, 2010 | 03:33 AM
55 f350's Avatar
55 f350
yep and what won't bolt too it directly there are plenty of adaptors out there to make 'em fit .....................
Old Sep 15, 2010 | 09:50 AM
skuzzel_butt's Avatar
skuzzel_butt
auto - c4, aod, small bell c6
manual - t5,t56,tko, most manuals bells are available for 302
just need the right flex plate or flywheel with 50oz imbalance for the late model 5.0
joe
Old Sep 15, 2010 | 11:56 AM
rockher_man's Avatar
rockher_man
Talking choices...
...what else are ya changin'?
Rearend...just gears......
How radical ya wanna get...ha-ha...just kidding......
NOW the fun starts...
Old Oct 20, 2010 | 12:38 AM
SVT-F100's Avatar
SVT-F100
I, as well will installing a 5.0 HO. Mine came out out of a 93 tbird. At this point I have purchased a 8.8 rearend off of splorer. It is complete caliper to caliper. But I am still looking for a transmission. I initially wanted to go with a t-5. After consulting with FTE members they mentioned that manual may be in a bad position if i wanted to keep the bench seat. I decided to go with an auto. It will be a c4,6 or AOD but at this point I am not sure if there is any pros or cons in the three. So I am just looking for the best deal.
Old Oct 20, 2010 | 01:23 AM
52 Merc's Avatar
52 Merc
The C4 fits great without cutting or big modifications. The AOD gives you the advantage of overdrive for increased economy. The C6 is beyond overkill for a 302 and really saps the horsepower to the rear wheels, as there's a lot of drag through that box. Figure on losing about 50 of the 220 horsepower the 302 will put out using the C6, or about double of the other two.
Old Oct 20, 2010 | 01:59 AM
CHELLIE's Avatar
CHELLIE
Install a new front Dampener, that is one of the weak spots to the 302, they will sometimes work loose and mess up the crankshaft end, Ask me how I Know replace the timing chain with a double roller assy. use lock tight on the retaining bolt on the dampler, also on the C4 trans, remove the front weak thin intermediate band, and install a heavy duty intermediate band, the stock band is like a thin piece of sheet metal and break easy, also install a shift kit in the trans, with a trans cooler that will make it last longer, use 3.50 to 3.70 rear end gears, hope that Helps, Chellie
http://www.atiracing.com/pdf/ATI_Catalog.pdf
FORD C4 C-4 TRANSMISSION HD KEVLAR INTERMEDIATE BAND: eBay Motors (item 200531636786 end time Oct-22-10 01:56:22 PDT)
http://www.mustangsunlimited.com/EM_...rint/00085.pdf
russellkr
Nov 2, 2002 11:18 AM
beartracks
Oct 18, 2002 02:20 PM
dale i
Sep 22, 2002 09:37 AM
rogwelch
Feb 12, 2000 11:29 PM
Jan 28, 2000 06:08 PM
