This is my uncles truck that he's owned longer than I can remember and after sitting for a long time he finally decided to rod it its been finish for a couple years now I thought you might like to see it
see if you can tell all the changes he made to the body
enjoy
Jeff
"see if you can tell all the changes he made to the body"
first I like it......
1. chopped top
2.split windows
3.pie cut hood
4.custom bumpers
5.custom tail lights
6.square bed rails
7. custom running boards
8. recessed headlights
9. bed tubs
10. custom mirrors
did I miss any?
That looks great I had a 55 F100 custom cab, I put in a 312 t bird eng in it with 3-2 barrel strombergs, 3/4 dempsy 280 cam grind, milled the heads .060, headers, replaced the auto trans with a 3 speed stick, and the truck would do 15s in the 1/4 mile, with some wide low profile wide tires the rebuilt eng lasted 18 years, My Father gave me the truck to use while i was going to high school, I rebuilt the eng at My HS school auto shop, I used the truck for about 3 years, then gave the truck back to my Father, He became a Teenager again when he got into that hot rod truck
