two oil dipsticks?
Old Sep 13, 2010 | 08:01 AM
howdy71475's Avatar
howdy71475
two oil dipsticks?
I am working on this 292 for a 61 unibody, although I know this engine has been rebuilt I believe it's the orignial, but it has two oil dipsticks in the right side of the block. When I was driving this truck ten years ago, I thought that it had one stick in the timing cover, and one in the middle of the right side. Now that I have it out, and cleaned up, it has both dipsticks in the block, one right behind the timing cover, and one in the middle. So now I have a spare timing cover, and no idea how to get rid of, or which to get rid of, extra dip stick. The one on the front of the engine has been cut off at the full mark, and reads the same as the one on in the middle.
Any ideas anyone has would be a great help. Thanks in advance.
Howard
Old Sep 13, 2010 | 09:54 AM
Y-Blockhead's Avatar
Y-Blockhead
Simple, If you have a rear sump oil pan, use the rear dip stick. If a front sump, use the frond dip stick.
Old Sep 14, 2010 | 03:58 PM
charliemccraney's Avatar
charliemccraney
Are you sure the front dipstick is in the block?
Plugs for the dipstick hole are available at napa. I can't remember the size. Just measure the dipstick and get a plug the same size.
SoArkSI
23
Jan 26, 2015 03:07 PM
engine14
Mar 22, 2014 04:13 PM
bburrito
Jun 5, 2011 05:15 PM
db1068
1978 - 1996 Big Bronco
37
Jul 17, 2010 06:56 PM
Steve A
Nov 13, 2004 09:02 PM
