oil dipstick ?
Old Nov 17, 2005 | 05:27 PM
SoArkSI's Avatar
SoArkSI
oil dipstick ?
i have a 77' f150 with a 351M that i am positive of, and a 79' f150 that says on the VIN has the same motor. the 77' oil dipstick is on the drivers side beside the motor, but the 79's stick is on the front of the engine by the alternator. is it really the same engine with different dipstick locations or has someone swapped the motors????
Old Nov 17, 2005 | 06:15 PM
ford390gashog's Avatar
ford390gashog
the cleaveland used a dipstick in that location.
Old Nov 17, 2005 | 06:28 PM
SoArkSI's Avatar
SoArkSI
in that location as in front of the motor by the alternator or on the side of the driverside of the motor?
Old Nov 17, 2005 | 06:31 PM
ford390gashog
by the alternator.
Old Nov 17, 2005 | 06:37 PM
SoArkSI's Avatar
SoArkSI
did they make a 400C? or just a 400M? because i was going to take the oil pan off and check the code to see if it was 351 or a 400. so does that mean that i could take the valve covers or the heads off to see if they are the cleaveland head?
Old Nov 17, 2005 | 06:48 PM
LxMan1's Avatar
LxMan1
The heads are the same for a 351C and 351M and 400.
They quit producing the 351C in the states in 1974. They were never put into trucks.
The 460 has the dipstick in the timing cover behind the waterpump. How many bolts are in the valvecovers in the 79?
Old Nov 17, 2005 | 06:55 PM
SoArkSI's Avatar
SoArkSI
well the truck is at my parents house, but i kinda have a idea that the motor has been swapped cuz the motor mounts are home made on the bottom, there is no sticker on the blue valve covers, but i will hafta count the bolts tomorrow. i know it has a DEEP growl to the exhaust too.
how much bigger is the big block vs. the 351-400??
Old Nov 17, 2005 | 07:07 PM
ford390gashog
the blocks look the same. also the 400 is just a 400 not a 400m.
Old Nov 17, 2005 | 07:10 PM
SoArkSI's Avatar
SoArkSI
so would the easiest way to tell if it is a 429/460 to count the valve cover bolts??? because with the front dipstick it cant be the same 351M motor that is in my 77'
Old Nov 17, 2005 | 07:43 PM
SoArkSI's Avatar
SoArkSI
are there more on the 429/460????
Old Nov 17, 2005 | 08:09 PM
77f2504by4's Avatar
77f2504by4
2wd 351m/400 trucks had the dipstick in the block (on the front of the block behind the alt.) and 4x4 trucks have the stick in the pan on the drivers side. if the trucks not 4x4 it could be a 2wd transplant!
Old Nov 17, 2005 | 08:23 PM
SoArkSI's Avatar
SoArkSI
ok heres the thing my VIN shows the truck as bein a 351 2wd, but the frame is original 4x4 so maybe it is a transplant or a new frame????? ima pull the oil pan to see if it is a 351 or a 400m
Old Nov 17, 2005 | 08:25 PM
ford390gashog
7 bolts=460 8=351c,351m,400
Old Nov 17, 2005 | 08:27 PM
Icicle's Avatar
Icicle
335 series motors have 8 valve cover bolts..... and a 12.7 inch intake width for the 351M and 400, the clevelands intake is narrower.
429/460's have 7 valve cover bolts, I believe its 4 on the bottom and 3 on the top.
My 429 came out of a car, it has the dipstick up front passenger side by the alternator....
hope that helps, there is a sticky up at the top f this forum that has more identification information......
Old Nov 18, 2005 | 05:00 PM
77f2504by4's Avatar
77f2504by4
does the pan have a front or rear sump oil pan?
