"Fuel Filter" light
Old Sep 13, 2010 | 06:54 AM
Robbgt's Avatar
Robbgt
"Fuel Filter" light
Hey guys, I can't believe I'm asking this (I should know by now...) But does anyone have info on the "Fuel Filter" light? (NOT the water in fuel)
Where is the sensor for this? And can it be cleaned? (like the FPR screen?)
The light does not come on at idle, then comes on under moderate accel and goes off at about 75 MPH (2K RPM's)
Filter was just changed 2K miles ago and the old one didn't look bad.
Thanks guys
Robb
Old Sep 13, 2010 | 07:03 AM
Hussler's Avatar
Hussler
It's just a sensor and is the top one, drivers side on the filter canister. They are prone to leaking at the electrical connection. About $25 at IH. Check your fuel pressure and make sure it's up to par.
Old Sep 13, 2010 | 07:10 AM
Robbgt's Avatar
Robbgt
Ok cool thanks. come to think of it, I'm pretty sure mine is leaking a bit of fuel... I'll re-check pressure Have new puel pump and shimmed the FPR to 75 lbs I believe.
Thanks
Robb
Old Sep 13, 2010 | 08:35 AM
Robbgt's Avatar
Robbgt
Any Idea what the part number at IH might be? I can't seem to find it...
thanks
Robb
Old Sep 13, 2010 | 08:51 AM
Hussler's Avatar
Hussler
It's called fuel filter restriction sensor or fuel filter vacuum switch.
Ford E8TZ-9S283-A
International 1809435c1
Old Sep 13, 2010 | 08:55 AM
Robbgt's Avatar
Robbgt
Thank you sir
Robb
Old Sep 13, 2010 | 03:34 PM
plgebbia's Avatar
plgebbia
Thanks for the International part #!
I just paid $62.00 for the blasted thing from Ford
Old Dec 6, 2010 | 05:56 AM
Robbgt's Avatar
Robbgt
UPDATE:
The part was $25 plus tax at IH. Took 5 min to install with a pair of channel locks. Problem solved. Thanks all
Robb
bryanlindborg600
Oct 30, 2011 10:07 PM
SCROWLEY707
17
Mar 9, 2010 02:08 PM
adambomb
Aug 28, 2009 02:21 PM
ngng
Aug 17, 2009 09:00 PM
marcs724
Feb 7, 2007 11:58 AM
