How many fuel filters?!?
Old Feb 6, 2007 | 08:50 PM
marcs724's Avatar
marcs724
Ok someone answer me this once and for all. Where is the other fuel filter on my '02 7.3?!?!? I bought the truck used, and didn't get the second diesel supplement owners manual with it, dealership and parts store says it only has the one on top of the engine, but i've seen people on here talk about another one. Does it have 2? If so where the heck is it???
Oh and when the water in fuel light comes on... how do you drain the water??
Thanks guys!!
Old Feb 6, 2007 | 08:59 PM
guzzle92's Avatar
guzzle92
There is only one on the stock 7.3. Top of the engine in the round canister. The drain valve is the yellow lever at the rear of it. 90º turn and it's open. Make sure you place an additional piece of hose on the drain tube under the engine to keep it from making a mess all over the ground.
Old Feb 7, 2007 | 08:19 AM
ponch37300's Avatar
ponch37300
Guzzle is right the 7.3 only has one fuel filter unless someone put an extra one on. If they did it should be on the frame rail in between the fuel tank and fuel pump. The 6.0 has two. There have been alot of trouble with the o-rings for the fuel drain valve. They are cheap and wouldn't hurt to get some in case yours go when you open the valve.
Old Feb 7, 2007 | 09:13 AM
2002f2507.3LPS's Avatar
2002f2507.3LPS
how often should we be turning that?
Old Feb 7, 2007 | 09:16 AM
ponch37300's Avatar
ponch37300
I started reading about o-ring leaks when the ultra low sulfar diesel came out. That seems to be the culprate or maybe it's just a coinsidense. I only turn mine when i change the fuel filter. I haven't had mine leak yet but i bought a couple o-rings to have on hand just in case.
Old Feb 7, 2007 | 11:06 AM
MTDewX's Avatar
MTDewX
I have already changed my O-rings. thanks low sulfer diesel folks. what is next to go bad because of it?
Old Feb 7, 2007 | 11:36 AM
Sabre2th's Avatar
Sabre2th
I drain mine every oil change...
Tom
Old Feb 7, 2007 | 11:58 AM
madjak's Avatar
madjak
Sabre2th,
Great step by step instructions and the pics make it look easy!
This will help anyone with the 7.3 that does their own work.
Jack
waystro
13
Sep 20, 2021 01:41 PM
90pioneer
Nov 3, 2013 08:23 PM
79OldBone
Jan 9, 2012 10:49 AM
artfd
Jan 1, 2012 08:13 PM
jmbatlanta
May 2, 2003 08:35 PM
