Carb questions
Old Sep 12, 2010 | 12:09 PM
james gang 1001's Avatar
james gang 1001
Carb questions
I have a 1964 Mercury 390 out of my old Marauder in my '55 F-100. The engine oil smells a little like gas, must be leaking through somehow. The numbers on the carb are as follows:
FoMoCo
C4AF-DJ
A4CA
I assume this is the orig. carb (bought the car with 63,000 miles on it). Does anybody know the size of the carb? Can and should I get a rebuild kit? Or is there anoter way to solve this.
P.S. I'm on a real low budget!
Thanks
Old Sep 12, 2010 | 01:09 PM
Bear 45/70's Avatar
Bear 45/70
C4AF-DJ; Says the carb is of a 1964 vintage so probably the original. Is it a Holley or a Ford carb? However almost all 390 engine 4 barrels were in the 600 CFM range with vacuum secondaries.
Old Sep 13, 2010 | 11:22 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I'd check the fuel pump and make sure it's not leaking gas into the crankcase.
Old Sep 14, 2010 | 09:46 PM
james gang 1001
KREWAT, would I check the gasket (at the block?), or what would I check for the fuel pump? Is there a gasket.
Thanks
Scott
Old Sep 14, 2010 | 09:59 PM
Bear 45/70's Avatar
Bear 45/70
The diaphragm in the fuel pump will be leaking. On the cheap pumps the fuel will leak thru the actuating arm opening into the crankcase.
Old Sep 15, 2010 | 07:55 AM
krewat's Avatar
krewat
Bear is correct, the pump can leak raw gas right into the crankcase, around the arm. I was lucky when my pump went with the original 360 in my highboy, it leaked out the vent hole instead of into the crankcase.
Old Sep 15, 2010 | 08:17 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
FoMoCo C4AF-DJ
C4AF-DJ = C3AZ9510AK .. 4V Ford (Auto-Lite/Motorcraft) 4V Carburetor.
Original applications 1963/64: Ford Custom/Galaxie/500XL & Thunderbird 390 / Mercury Monterey/Montclair/Marauder/S-22 390.
C2SZ9A586D .. 4V Ford (Auto-Lite/Motorcraft) Carburetor Kit (Motorcraft CT191A)
Fits: 1961/67 289/352/390/410/428 Ford 4V carburetors.
Oct 20, 2015 11:09 PM
reamer
Mar 30, 2014 12:27 PM
Raptor119
Apr 8, 2012 12:25 PM
crescentwrencher
May 10, 2008 09:40 AM
crystalbluevib
Aug 23, 2007 11:03 AM
