Carburetor Change
Old Oct 20, 2015 | 08:15 PM
1738509's Avatar
1738509
Talking Carburetor Change
If I change my 1967 F100(352 Big block) from a two barrel carb. to a 4 barrel carb. will it improve its performance and horsepower? If so what is the best type of 4 barrel carb. to purchase?
Old Oct 20, 2015 | 08:47 PM
HIO Silver's Avatar
HIO Silver
FE engines have notoriously restrictive exhaust systems. You first consideration is to switch to headers and dual, mandrel bent tubes and free flowing mufflers.
Now that the exhaust side is done, a dual plane 4V intake manifold and carb. A stock cast iron manifold is OK, an Edelbrock Performer, or a Performer RPM.
For a 352, stick with a stock 4V or Performer topped with an Edelbrock 1405 or 1406... choke style is your choice.
.... and the FE isn't a 'big block' per se since its basic block can be as small as a 330 all the way to a 428 while being externally (dimensionally) identical.
Old Oct 20, 2015 | 08:58 PM
Lneidlinger's Avatar
Lneidlinger
Something like a 600 cfm vacuum secondary carb will give you a bit of a boost in the top end while maintaining low end performance and driveability. Other important things you should consider, if you haven't already, is an electronic conversion for the distributor like pertronix. You would be surprised by how much that will wake up your engine as well. Switching to electric fans can also make your engine feel a bit more responsive.
As for a specific carb, something like this is a good traditional choice.
Old Oct 20, 2015 | 09:01 PM
HIO Silver's Avatar
HIO Silver
An Edelbrock is a better choice for new enthusiasts IMO. They're less fussy than a Holley.
Old Oct 20, 2015 | 09:08 PM
Lneidlinger
I totally agree. I have always tinkered with Holleys, and know poop diddly about Edelbrocks as far as what to recommend.
Old Oct 20, 2015 | 09:12 PM
351Cleveland C4's Avatar
351Cleveland C4
I agree. I like Edelbrock much better. Very very reliable carbs.
Old Oct 20, 2015 | 09:14 PM
HIO Silver's Avatar
HIO Silver
I concur with your recommendations for a 600 cfm with vacuum secondaries.
.. the OP has to got deal with the exhaust before embarking improvements to the intake side of the engine. Failing to do so would be like asking a sprinter to run a 100-yard dash while breathing through a straw.
Here's an excellent article: FE Exhaust Manifolds and Why You Probably Want Headers
Old Oct 20, 2015 | 10:58 PM
72Truckin's Avatar
72Truckin
To go from a 2V to a 4V carb, I'm sure you'll need a 4V intake manifold to accommodate the bigger carb.
Old Oct 20, 2015 | 11:09 PM
HIO Silver's Avatar
HIO Silver
There is the option to stick with the OEM 2V manifold and go with a 500 cfm, 2V Holley.... but what fun is that?
https://www.holley.com/products/fuel.../parts/0-4412C
Based on my butt dyno, headers, dual exhaust and a 4V setup is worth about 40 to 50 HP net.
jazzb97
15
Nov 4, 2017 08:41 AM
57style
Feb 21, 2017 04:50 AM
brigga72
Jul 23, 2011 08:35 PM
BLaCkSiLo
28
Mar 5, 2004 12:48 PM
gordo868
Apr 5, 2003 10:37 PM
