4 corner carb idle circuit setup
Old May 9, 2008 | 07:13 PM
crescentwrencher's Avatar
crescentwrencher
ive been looking at a new carb for my truck, and was wondering how the four corner carb setup works, how do i jet them? how do i set the idle mix?
Old May 9, 2008 | 08:21 PM
65f100_352's Avatar
65f100_352
What brand? Holley, Demon?
Old May 9, 2008 | 08:54 PM
crescentwrencher
Demon, though i think that demon uses all holley parts, power valves, gaskets, jets, accelerator pumps etc.
i only have enoughjets to have two in at a time, so i was wondering if i could find which jet size i need using just the primaries then when i find out, order the size jets i need.
or do the secondaries take a different jet size than the primaries?
Old May 9, 2008 | 09:49 PM
fastfarmer's Avatar
fastfarmer
Four corner idle adjusts very much like any other one. I've done it but it's been a very long time ago and I can't remember the specifics but it was not too hard. I usually ran one or two sizes bigger jets in the rear, jets are the same. New carbs usually come jetted pretty close to optimum, often just a little rich.
Old May 10, 2008 | 02:54 AM
johnboy427's Avatar
johnboy427
The four corner idle shouldn't change jetting at all, I have road demon 625 and I just screwed them all the way in and then out one turn as a starting point the only hard part was trying to remember which ones you had turned and which ones you hadn't, mine wound up idling great at about 800-850rpms with the rear just about 1/4 turn richer, and that with decent sized cam and a single plane intake.
-Johnboy
Old May 10, 2008 | 09:40 AM
Mudd460's Avatar
Mudd460
You can hook up a vacume guage and adjust the 4 corners for the highest vacume. Once you get your idle circuit set, you can select your jets. I like to do it by reading the plugs.
Tkc432
22
Jul 6, 2015 06:14 PM
skipper
22
May 1, 2015 03:07 PM
CharlaineC
Oct 26, 2014 10:16 AM
2speed
Flathead V8 & Flathead 6
Dec 8, 2002 05:01 PM
Dave
Jan 13, 2000 07:28 PM
