gpr led mod
Old Sep 12, 2010 | 11:36 AM
bigbubba87's Avatar
bigbubba87
gpr led mod
i decided to do the gpr led mod today. i went to radio shack and got the led and the only wire they had that was 22 gauge was copper core can i use this wire or should i just use 18 gauge regular wire? can i use just a regular fuse, or do i need a really small one? do i have to use a fuse at all?
Old Sep 12, 2010 | 11:47 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
You should be fine with 22 gauge, but a little larger might be better. Just fuse it with something that is a small amp rating and you should be good to go.
Old Sep 12, 2010 | 12:13 PM
bigbubba87's Avatar
bigbubba87
like a 5amp regular fuse? ive got 15amp but thats probly too big. i used 18 gauge wire i didnt know if the other stuff would stand up to the heat
Old Sep 12, 2010 | 03:28 PM
bigbubba87's Avatar
bigbubba87
i finished the gpr led mod. i tried to put some pictures on here but it keeps saying upload failed
Old Sep 12, 2010 | 08:33 PM
Ponyboychris's Avatar
Ponyboychris
I used a 2 amp fuse in an in-line fuse holder.
Old Sep 12, 2010 | 11:07 PM
bigb56's Avatar
bigb56
22 gauge is fine for the load of the LED. I used 18 just for mechanical strength. Also, the LED draws so little you can use a half amp fuse or less. Whatever your fuse is it is basically protecting against burning your truck up if your wire gets chafed and shorts out.
MiamiPSD
Mar 7, 2013 07:25 PM
Liquid10Rider
15
Jul 8, 2010 08:32 AM
Beeler
May 16, 2010 09:39 AM
DieselBeast01
39
Mar 10, 2009 10:31 AM
powerstroke1869
47
Feb 6, 2008 07:56 AM
