GPR Led mod question.
Old Jul 6, 2010 | 04:51 PM
Liquid10Rider's Avatar
Liquid10Rider
I was told by another member on FTE to do the GPR led light mod and after looking into it I figured for the small amount of money for the led and the free wire and fuse holder from work why not its a great mod. My only question is, Ive only seen one led but I looked under the hood the other day and there are two relays. Should I install one for the one bank and another to another bank??
And I have looked under the dash to find a spot to feed wiring out into the engine comartment but couldnt find a hole or anything. Maybe I didnt look hard enough??
What size fuse is everyone using? I know leds arent using really anything but just looking for a general fuse size?
Thanks,
-AJ
Old Jul 6, 2010 | 05:05 PM
Ponyboychris's Avatar
Ponyboychris
The relay to the rear of the two is the glow plug relay. See pic. That's the one to tap your wire to. If you look at your parking brake pedal under the dash, you should see a bundle of wire with a silver tag on them saying "customer access." Those wires pass through the firewall into the engine compartment right up by the master cylinder. Use one of those wires to pass through for your LED. I used a 2amp fuse.
Old Jul 6, 2010 | 06:48 PM
Liquid10Rider
thanks for the help! what is the other relay for?
Old Jul 6, 2010 | 06:53 PM
megawatt00's Avatar
megawatt00
The other relay is for your AIH (Air Intake Heater). Very rarely comes on.
Old Jul 6, 2010 | 06:54 PM
Ponyboychris
The front relay is for the Air Intake Heater. Not necessary thingyabob that most of us delete. Here's some info: Riffraff Diesel: RDP AIH Tapped Fitting
Old Jul 6, 2010 | 07:00 PM
Liquid10Rider
perfect! thanks guys! I'm actually looking in to doing the aih delete . I live in jersey and not sure if it will effect anything. from the other posts I have read it seems like it won't effect anything.
Old Jul 6, 2010 | 07:04 PM
Ponyboychris
Don't need it here in Colorado!
Old Jul 6, 2010 | 07:05 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
x2!!! And for last year while I was back in MD, my truck didn't miss a beat from not having it.
Old Jul 7, 2010 | 01:41 AM
superduty4x4's Avatar
superduty4x4
The second relay is actually the self destruct relay. If you mess with it... you have 30 seconds before your truck blows itself to bits. Hope you didn't mess with it!
Old Jul 7, 2010 | 11:09 AM
SteveH-CO's Avatar
SteveH-CO
When you 'delete' the AIH, do you just unplug the element?
I saw the adapter on riff raff's page, but no instructions on what you do with the AIH element itself. I presume removing it won't throw a code, right?
Old Jul 7, 2010 | 11:37 AM
SpringerPop's Avatar
SpringerPop
You can replace it with a Cummins oil drain plug or any number of aftermarket custom ones.
Pop
Old Jul 7, 2010 | 02:26 PM
Ponyboychris
Pull the element, remove the red lead wire from the relay to the element, and remove the ground wire (or unhook from the element and let it hang in the engine valley) and you are done. It will throw a soft code but set off the SES light.
Old Jul 7, 2010 | 02:38 PM
Liquid10Rider
I know im going way off topic but chris in the picture you posted earlier right near the red circle there is a brass t fitting. Is that for a fuel pressure guage?
Old Jul 7, 2010 | 02:59 PM
CSIPSD's Avatar
CSIPSD
That is for a boost gauge.
Old Jul 8, 2010 | 07:20 AM
Ponyboychris
Yup. Boost gauge tee fitting. Gee, How'd you know that, Joe???
