Brake Lines
Old Sep 12, 2010 | 09:30 AM
spedbugy's Avatar
spedbugy
Brake Lines
I recently purchased an '88 Ranger 4wd, regular cab. Yesterday the steel line going to the rear brakes broke. Does anyone know the length of this line? I figure I should replace the whole thing on a truck this old to avoid chasing other weak spots in the line.
Old Sep 12, 2010 | 09:37 AM
grandmas77f150's Avatar
grandmas77f150
Why can't you just buy a replacement brake line?
Old Sep 12, 2010 | 10:39 AM
Danger_Dave's Avatar
Danger_Dave
just had this problem with my dads buick. the rear line was corroded so bad it had a pinhole leak. i went to the closest dealer and ordered a new one for 25 bucks. then while we were bleeding it, the front brake line blew out for the same reason! unbelievable
now for the front one we bought a bender, rented the double flaring tool. bunch of brake line, and fabbed a new one. once you practice it a few times, you realize that you could do all custom brake lines for a whole car and its not that hard.
Old Sep 12, 2010 | 02:32 PM
spedbugy's Avatar
spedbugy
Does Ford still sell a pre-bent line for this old of a truck?
Old Sep 12, 2010 | 03:51 PM
grandmas77f150
Go to a parts store before you go to a stealership
Old Sep 12, 2010 | 04:41 PM
V8Ranger302's Avatar
V8Ranger302
You don't have to buy prebent line. Just take off both fitting at each end or the line, measure how much you need, got to the parts store and tell them you need X amount of line and they have to have these ends on them. They will give you a union to put two line together. Its not hard..
Old Sep 12, 2010 | 05:13 PM
spedbugy's Avatar
spedbugy
The parts stores don't sell a replacement line, just the make it yourself generic line.
Old Sep 12, 2010 | 05:43 PM
G2IC_Wraith's Avatar
G2IC_Wraith
I had to make all of my own hard lines. I looked as well, and no one seemed to make them. I went with stainless lines you can order from Jegs. Just order all the length you need.
Old Sep 13, 2010 | 12:13 AM
ford2go's Avatar
ford2go
What little I know
- Napa sells line in various standard lengths with ends on
- You can pick up a cheap bender -- it's a good idea
- I've read that you can use a string to get an accurate length measurement -- it should work
- dealer is very unlikely to have a replacement
- Some parts stores may make up lines for you -- but they would probably be non chain stores
Flaring is a little bit of an art (not one that I know). You want a good tool
(and you want to put the 2nd fitting on the line before you finish flaring it )
You can buy complete replacement pre bent sets on line (every line for your vehicle) They're not cheap . I think that one place is classictube.com
G2ICk, I'm glad that you had good luck with stainless -- everything that I've ever seen said that they were very difficult.
Old Sep 13, 2010 | 04:41 AM
V8Ranger302
If you have to bend it your self which is no big deal at all, I will use a socket or spray pain can to bend lines when I have to do them for people. No kinks, works pretty good... Your lines that run from front to back dont have any real sharp bends anyway. Just the one where it will go into the spliter for the rear lines. And that not usually a very sharp bend. They dont have to match the original lines. They just have to make it from A to B and not rub or be kinked.....
Mark62
Dec 8, 2013 09:30 PM
brighteyes818
May 11, 2013 01:32 PM
flip4eva83
Nov 14, 2011 12:17 PM
SasquatchF-250
Jan 9, 2006 10:10 PM
rhetor
Jul 11, 2003 01:46 PM
