Brake lines
Old May 10, 2013 | 08:19 PM
brighteyes818's Avatar
brighteyes818
Brake lines
I have a 2002 F350 7.3L and I replaced the brake lines with Nicopp nickel copper alloy lines (none rusting lines) last year, just to get the truck up and running... Now I want to tow a 9000lb travel trailer and I want to know if these lines will be strong enough? or should I change them to something else,,, like steel....
Old May 10, 2013 | 09:17 PM
BadDogKuzz's Avatar
BadDogKuzz
First of all the Nicopp nickel copper alloy lines are SAE Standard J1047 and ISO 4038, so they are "Good to Go!" After reading this I wish I would used these when I replaced the long brake line from the front of the truck back to the diff. Because as I recall it had about 14 or 15 bends in it. So incase you haven't read this, this will put your mind to easy. AGS Company - NiCopp
So thanks for pointing out the Nicopp nickel copper alloy lines since I have to replace ALL brake lines on my old motorhome and my boat trailer this spring. I'mm going to give them a try. Where did you buy they. I am looking for a 100' roll.
Old May 10, 2013 | 09:19 PM
snakedoc's Avatar
snakedoc
i would think they would work.
where do you get them or did you make them?
Old May 11, 2013 | 04:30 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
My question is, why would towing a trailer add extra pressure on your brake lines? I dont think it would.
Old May 11, 2013 | 05:22 AM
cjgray1974's Avatar
cjgray1974
Unless your trailer brakes don't work, then you might have to mash on them pretty hard. Or if they go out at an in-opertune time like the ones did on my hay trailer last summer. Had a death grip on the wheel and both feet standing on the brakes
Old May 11, 2013 | 08:10 AM
tjc transport's Avatar
tjc transport
i ain't rite
that is all i have used the past 5-6 years.
i will never use steel lines again on anything.
Old May 11, 2013 | 09:49 AM
brighteyes818
We got these from Advance Auto, bent them up myself..
Old May 11, 2013 | 10:03 AM
brighteyes818
Well while doing some research over the winter, I thought I saw an article/maybe video that said, the more bends in it the less strength it had,, just checking to see if anyone can clarify
Old May 11, 2013 | 11:13 AM
Snowseeker's Avatar
Snowseeker
It is what I am going to use on everything from now on around here! IMO it should be stock from the factory simply for safety reasons.
Old May 11, 2013 | 01:32 PM
cjgray1974's Avatar
cjgray1974
Not sure about strength, but small sharp bends will cause the fluid to get to hot and reduce the braking ability.
flat48f2
Feb 19, 2016 12:22 PM
regidog
Feb 23, 2012 09:46 AM
neilc88
Feb 13, 2012 08:37 AM
Red97350
Jan 27, 2010 10:17 PM
